Thread: trans surging and trans temp issues.
Results 1 to 13 of 13
  1. #1 trans surging and trans temp issues.
    SE Level Member kawasaki22106's Avatar
    Ford City, Pennsylvania, United States
    im looking for some help here, i have a turbo car with a built trans (3.52 GMR chain and gears) running a 2700 stall converter from cartuning. i have a external trans cooler and i am still using the factory cooler as well. i am seeing temps up to 220 degree street driving and cant keep it cool. for all you turbo car guys what is your setup to keep the trans cool and what stall and gearing are you using?
    second issue is once i am in 4th gear cruising the converter locks up as it should and stays locked from barely any throttle to about 10% throttle. once i hit 10% throttle it starts surging (converter lockup and unlock) until around 20% throttle and then after 20% throttle it will stay locked up until i sink into the throttle hard enough to unlock for power. why am i having this surge issue?
    665whp 584ft lb torque
    93 pump fuel+meth on 26psi
  2. #2 Re: trans surging and trans temp issues.
    GT Level Member Shiftingshaddow's Avatar
    KC
    i have no idea but you're profile picture is awesome. i hate that show.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  3. #3 Re: trans surging and trans temp issues.
    John.. that sounds to me like the gear ratio is not 100% correct in the programming. I'm saying this from experience. I'd be speaking to Dave for any insight on how to do it properly.
  4. #4 Re: trans surging and trans temp issues.
    Bill, it did this with the 2.93 gearing and the 3500 stall as well though also....
  5. #5 Re: trans surging and trans temp issues.
    That was a 3500 stall.
    You asked a question, I'm merely trying to help based on the worlds pickiest, most finicky Bonneville in history. That car earned the name Black and *****y from Pman
  6. #6 Re: trans surging and trans temp issues.
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    I'm would have also said incorrect gear ratio. I see the post about high trans temps after gear ratio chance pop up ever 6 months or so on the forum. Other than that, did you flush both aftermarket cooler and cooler in the radiator before installation? Depending on what type of trans failure you had earlier there could be a ton of junk that was put through those coolers.
    Edit: About the surging I had a similar issue after I installed my trans but after about 100 miles the pcm had enough time to go through the re-learning process and went away. I emailed Dave about it and said that if it wasn't gone in 2 day of stop and go driving to give him a call....went away before 2 days.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  7. #7 Re: trans surging and trans temp issues.
    GTP Level Member
    Pittsburgh
    Gears are set in HPT to be a 3.52 Ratio with the correct tire size. I had a thought this morning, trying to play around with the TCC Release speed. Im thinking that it might be too close to the apply and its getting unhappy
    2003 SSEi,
  8. #8 Re: trans surging and trans temp issues.
    P... could be.. However he's using a 3.29 diff, with I forget gear tooth count on the gears.
    What I'm getting at is.. if you have 3.29 diff and 1:1 ratio gears, you start with a stock 2.93 file (which says 3.29) and you change it to 3.69, toss in teh tires and hit auto.
    Sooo under that logic, programming may be off and I'd be chatting with Dave to get any info on how he might derive it.
    Hmmm phone rang, it's a PA number.
  9. #9 Re: trans surging and trans temp issues.
    John..
    We spoke and did some math. If that doesn't work, speak to Dave. I believe we did it right (which probably means it'll be wrong).
  10. #10 Re: trans surging and trans temp issues.
    Awesome!!
  11. #11 Re: trans surging and trans temp issues.
    And ... Greg tossed a number at me in chat w/o having been on the convo. Same number.
    Hopefully it works out.
  12. #12 Re: trans surging and trans temp issues.
    We changed the gear and it seemed to help with temps and shifting but the converter was still mad and surging. Kevin at Cartuning emailed me the tune he changed for me and me and pat were both surprised, he barely changed anything but what ever he did makes it lock correct. Its just weird....
  13. #13 Re: trans surging and trans temp issues.
    You know John.. Pat has some converter issues on his own. I have him a little info/tune and he loved it.
    Either way.. glad that worked out.
  1. Does anyone use a trans temp guage ?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-22-2013, 03:42 PM
  2. What's a normal trans temp for the 4T65E?
    By Vinson clark in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-31-2012, 08:32 PM
  3. trans temp
    By stishdr in forum General Tech Discussion
    Last Post: 07-31-2011, 09:31 AM
  4. trans temp
    By bigman93 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2011, 07:49 PM
  5. trans temp
    By gotboost3 in forum General Tech Discussion
    Last Post: 04-28-2009, 11:13 AM
