Thread: weird noise when off the gas ...
Results 1 to 6 of 6
  1. #1 Re: weird noise when off the gas ...
    Dec 2011
    chicago
    Quote Originally Posted by QUICKSILVER462 View Post
    A damaged thrust washer behind the sun gear in the differential will cause a noise when de-accelerating. When this washer/bearing "goes-out" it sends metal into the planet/ring/sungear chipping the teath, and the sun gear grinds into the diff.carrier, (audible noise). Metal will be found in the trans. oil pan.
    Is there an easy fix?
  2. #2 Re: weird noise when off the gas ...
    HUDSON
    Quote Originally Posted by ls1racer11 View Post
    "easy" is subject to opinion and experience, more of a PIA for me.
    I had to replace the differential housing because the sun gear scored the surface the thrust washer sits on, and the teath on the sun/planet/ring gear were chipped, so I replaced the diff. with a good used one accuired from a local tranny shop, it was $200 with next day shipping to thier shop, I installed it myself.
    Depending on wear/damage, gear teath, at the very least a new thrust washer has to be installed, and all the metal cleaned out of the pan. Fortunate for me, the magnet in the pan was directly under the fluid return hole from the diff. and captured most of the metal fragments. I changed the trans. filter and refilled with fluid, all has been fine since then.
  1. Help weird noise
    By macey43 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-10-2011, 09:56 AM
  2. Weird noise?
    By Points70 in forum General Tech Discussion
    Last Post: 10-19-2011, 12:18 PM
  3. weird noise
    By c32k05 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 10:47 AM
  4. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
