Thread: Shift solenoid question
Results 1 to 5 of 5
  1. #1 Shift solenoid question
    Michigan
    Hello, I went to Auto Zone today and the scanner showed up an issue with a shift solenoid. My 2001 Grand Prix is jerking when I accelerate. Do I have to go to the dealer to fix this? Thanks
  2. #2 Re: Shift solenoid question
    SE Level Member Melancholy43920's Avatar
    East Liverpool, OH
    Yeah you do. Just found out a little earlier mine is going bad too. No jerking, but when I hit the gas from a stop it revs up and barely moves, then gradually kicks in. The scanner said it was the shift solenoid. It's a $28 part (for my 97 GP GT) but since it goes inside the tranny it's probably gonna cost an arm and both legs to install. If it goes out completely the car will be undriveable, so I suggest you get it taken care of ASAP.
  3. #3 Re: Shift solenoid question
    Brewcity, WI
    I hate to be the bearer of bad news, but when mine went it was $800 to fix..... granted this was at the dealership. Thankfully it was still under warranty, whew.
    Self-denied SMGPFC member #1
    SEARCH works!
  4. #4 Re: Shift solenoid question
    Brewcity, WI
    Quote Originally Posted by Pepino View Post
    I only went there because of ^^
    SEARCH works!
  5. #5 Re: Shift solenoid question
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I don't know of anything at all you HAVE to go to the dealer for. If it is just the shift solenoid, any competent trans shop should be able take care of it. Hell, it could be done in a driveway without too much problem.
    2001 Buick Regal LS - Almost Stock
  1. 2007 P0753 shift solenoid A and no low beams
    By BrianS413 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-07-2010, 06:49 PM
  2. Shift lock solenoid
    By richard58 in forum General Tech Discussion
    Last Post: 11-17-2009, 04:45 AM
  3. Shift solenoid
    By Junixx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2009, 05:22 PM
  4. 1234 shift solenoid
    By ronaldgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-12-2008, 06:11 PM
  5. Transmission shift solenoid compatibility
    By BackInBlack in forum General Tech Discussion
    Last Post: 10-18-2008, 01:19 PM
