Thread: mystery leak on driveway only when parked on incline (even slight)
Results 1 to 5 of 5
  1. #1 mystery leak on driveway only when parked on incline (even slight)
    Aug 2012
    Richmond Hill, Ontario
    I have a 2004 Chev Venture LS with what I believe is the 4T65E transmission. I change the fluid once a year and notice the level is almost 100% at the end of the year. However, unless I park the vehicle in my level garage I will get a small drip (5-8 drops per night) occuring when the vehicle is parked on a grade, even a slight grade. I've wiped the pan and gasket area many times and it doesn't seem to be the source.
    Does anyone have any suggestions where this leak may be coming from? Should I worry about a no-drive condition? It's annoying to clean the drops each time I park on the driveway, but I really don't want to spend money if it's not a saftey issue.
    Thanks for your thoughts.
    Rob
  2. #2 Re: mystery leak on driveway only when parked on incline (even slight)
    Rob..when you say grade, nose up or nose down?
    I'm assuming nose up. If so, then that would be a tweaked spot or rust bubble on the dipstick tube where the holding tab was welded to it. See pic
  3. #3 Re: mystery leak on driveway only when parked on incline (even slight)
    Aug 2012
    Yes, you are correct. It seems to be only nose up. I wondered about a reverse or forward servo cover leaking too. However, if it's just the dipstick tube I don't think I need worry too much. You think?
    Strikes me odd also, that it has been like this since almost new. Maybe after a year it started?
  4. #4 Re: mystery leak on driveway only when parked on incline (even slight)
    Say someone moved the tube, just the right way (pretend I don't have extensive experience "adjusting" these things) and it ripped one of the welds a little. That is enough to do it.
    At most, I'd get under there...wipe it with a brake cleaner rag, then toss a little blob of RTV in the area. Let it dry and hope for the best. If you succeed, smile..if not.. say "oh well" and go on with life.
  5. #5 Re: mystery leak on driveway only when parked on incline (even slight)
    Aug 2012
    Thank-you. I'll do just that.
  1. Mystery oil leak
    By thatguy in forum General Tech Discussion
    Last Post: 04-17-2012, 07:58 AM
  2. Mystery coolant leak
    By 04silverprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2011, 11:35 PM
  3. Replies: 18
    Last Post: 11-29-2010, 05:19 PM
  4. my car was parked in a flood
    By Scottydoggs in forum The Rant Forum
    Last Post: 10-02-2010, 03:13 PM
  5. A somewhat empty driveway...
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 12-27-2008, 11:20 PM
