Thread: A/C Problem Any suggestions?
Results 1 to 6 of 6
  1. #1 A/C Problem Any suggestions?
    SE Level Member mycutlassblue's Avatar
    Louisville, KY
    98 GTP With dual climate control only blows out cold air on the passenger side. The left driver side blows out a little cooler air, but the center vents except the passenger arent blowing out any cool air..
  2. #2 Re: A/C Problem Any suggestions?
    swift current,sask.
    Blend door...
  3. #3 Re: A/C Problem Any suggestions?
    Banned
    Mansfield, Ohio
    Quote Originally Posted by whiney View Post
    Blend door...
    I agree and if the stereo's off you can hear the blend door move, at least in my car don't see why someone elses would be any different.
  4. #4 Re: A/C Problem Any suggestions?
    Louisville, KY
    Would you all happen to know how to fix this problem? Do I have to change the whole climate control unit?
  5. #5 Re: A/C Problem Any suggestions?
    Banned
    Mansfield, Ohio
    Quote Originally Posted by mycutlassblue View Post
    I'm not sure but seems logical unless the blend door itself is stuck, not sure maybe some hvac guru's will hop in here that have had their climate control out. Dual zone or manual climate control?
  6. #6 Re: A/C Problem Any suggestions?
    Louisville, KY
    It is dual, but the problem is pretty much fixed now. The passenger side I still believe blows the colder air, but I added another can of freon and now my side is working just fine.
  1. n/a gp gt need some suggestions
    By kyleheine298 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 12:26 PM
  2. cam suggestions?
    By 2000gprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2009, 12:39 PM
  3. need suggestions...
    By r33na in forum Visual/Body Modifications
    Last Post: 10-26-2009, 08:53 AM
  4. N/A suggestions
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2009, 11:38 AM
  5. Need Suggestions.
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 12-27-2008, 05:41 PM
