Thread: Tranny Swap & Aluminum Sub-Frame
Results 1 to 13 of 13
  1. #1 Tranny Swap & Aluminum Sub-Frame
    Apr 2012
    Bancroft. Ontario, Canada
    So, long story short, my car is gonna need a new tranny, and i'd looking to upgrade my rusted and cracked to sh!t subframe (i'm gonna have to invest in new Control arms too) and was thinking of the following....
    Would it be at all possible to drop engine trans everything out the bottom by disconnecting everything that needs to be, unbolting the front struts, subframe bolts and such and then dropping it, and removing engine and trans after all said and done.... If this procedure is at all possible, is there a write up on doing it (i've found "Engine and Transmission together" out the top threads.... Hot helpful for what i want to do...
    now the second part:
    Are the subframes in Regal's, Impalas and such compatible with 97-03 Grand prixs?? (i figure they would be considering their all w-bodies)
    Are they all Aluminum??
    & finally, are they at all of any good replacement for whats in there currently?? (I could possibly get a sub frame off a 01 impala or off 3 Buick Regal's at scrap)
    *if there was a g-p there i would have a ball getting parts*
    **Might just look into a cheaper full parts car like a GTP**
  2. #2 Re: Tranny Swap & Aluminum Sub-Frame
    I think only monte carlo's and impala have the aluminum subframes.
    And yes, you can just drop everything out the bottom.
    Make sure the trans you buy is the same as the one in your car now. (What is your car?)
    Or are you having it rebuilt.
  3. #3 Re: Tranny Swap & Aluminum Sub-Frame
    Jan 2012
    Philadelphia
    regals do to im pretty sure
  4. #4 Re: Tranny Swap & Aluminum Sub-Frame
    they dont.
  5. #5 Re: Tranny Swap & Aluminum Sub-Frame
    Apr 2012
    I'm buying another tranny, it's from a wrecked 02 GT with 97,000kms on it
  6. #6 Re: Tranny Swap & Aluminum Sub-Frame
    2000+ Impala/Monte
    2004+ GP (double check 04's though, I thought I heard some had the steel)
    Everything else fits right on it.
  7. #7 Re: Tranny Swap & Aluminum Sub-Frame
    OH..and to take it all out the bottom, you want a lift and a way to move the carcass once you drop it out. Because it's going to weigh over 1,000 lbs easily.
    Me, I prefer to pull out the top, then support the car, yank the ps rack off the subframe and drop it out.
  8. #8 Re: Tranny Swap & Aluminum Sub-Frame
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    I can get an aluminum cradle from LKQ self serve for 60 bucks here in Savannah, I was looking at doing the aluminum cradle as well. I did some research and found out that the 2003 and earlier Impala and Monte aluminum cradles are better because of the way they are made. the 2003.5+ started using an inferior extrusion design more apt to cracking. Just a little FYI. Here's the link i found that explains it.
    Learn me about aluminum engine cradles - The Chicago Garage
    4 out of 3 people have trouble with fractions
  9. #9 Re: Tranny Swap & Aluminum Sub-Frame
    Apr 2012
    Bill, would a A.T.V Jack do the trick
  10. #10 Re: Tranny Swap & Aluminum Sub-Frame
    Quote Originally Posted by Speedy1973 View Post
    im not BIll but thats what he uses, a ATV jack. works like a charm. jack it up to the pan, un bolt it, separate it, drop it, drag it out the d/s wheel well.. for a trans drop alone that is.
  11. #11 Re: Tranny Swap & Aluminum Sub-Frame
    Bettendorf, IA
    Ok, So the Aluminum Cradles will fit the 97-2003 Wbody's (Regal/GP/Intrique's) Correct?
  12. #12 Re: Tranny Swap & Aluminum Sub-Frame
    Yup.. W body is all the same.
  13. #13 Re: Tranny Swap & Aluminum Sub-Frame
    Bettendorf, IA
    Cool, these same as 04- GP, lacrosse, regal?
  1. General Info: Swap your steel oil pan for an aluminum one
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 04-05-2022, 01:42 PM
  2. sub frame swap
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2012, 11:19 AM
  3. tranny swap
    By gonzo915gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2009, 03:10 PM
  4. pcm help with tranny swap
    By ddyke2000 in forum PCM Tuning
    Last Post: 05-03-2009, 01:41 PM
  5. Tranny swap
    By kbradley in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 07:45 AM
