Thread: slips on left turns...
Results 1 to 3 of 3
  1. #1 slips on left turns...
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Hey guys. Yet another problem. I have a 05 Monte ss. When I make a left turn, no matter how fast I'm going the trans slips until I let off and straighten out. And starting yesturday it will slip if I accelerate kind of hard. Has 97000.
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: slips on left turns...
    St. Louis
    Check your fluid level. Sounds low. Have you ever changed the filter and fluid? If not now would be a good time to do so.
  3. #3 Re: slips on left turns...
    Left turn slip is a known fluid starvation issue. Intense Racing suggested overfilling the trans by 1 pint to work that out.
    Pint...not quart
  1. Replies: 4
    Last Post: 06-20-2010, 04:04 PM
  2. Transmission slips bad at WOT
    By Rather B Blown in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-13-2009, 07:08 AM
  3. loud squeak drivers side on left turns only
    By jsveen in forum Brakes/Suspension/Chassis
    Last Post: 05-26-2009, 08:20 PM
  4. time slips
    By justwhisen in forum Forum Bugs/Suggestions
    Last Post: 05-14-2009, 11:07 PM
  5. Power steering whine on left turns only...
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-03-2008, 12:19 PM
