Thread: Transmission slips bad at WOT
Results 1 to 11 of 11
  1. #1 Transmission slips bad at WOT
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    last night on the on ramp to the highway going about 30mph, i punch it, and it downshifts to first like normal, but as its pulling it really slips bad. its like it would grab, and slip out again like 4-5 times, i dont really know how to explain it. you could really feel it surge and buck. it only happens at WOT. Oh also, when you're going about 50-55mph and as it shifts into 4th it kinda slips and revs the motor before it shifts, but its always done that. the WOT thing just started last night.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  2. #2 Re: Transmission slips bad at WOT
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Check tranny fluid. If it is fine time for a rebuild
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: Transmission slips bad at WOT
    PA
    Quote Originally Posted by Toofastgs View Post
    My bet is the latter.
    2001 GSE
  4. #4 Re: Transmission slips bad at WOT
    Dec 2008
    London, Ontario
    fluid level was about half a quart low and it smelled kinda burnt not horribly but noticeable, i topped it up and its still doing the same thing. on another note could i use a tranny out of a gt to get the 3.29s? or should i just get a junkyard gtp tranny and put it in for now and build my broken trans with good parts and 3.29s.
  5. #5 Re: Transmission slips bad at WOT
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Burnt clutches or burnt fluid most likely
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  6. #6 Re: Transmission slips bad at WOT
    SE Level Member Boostd1's Avatar
    Thornton, Colorado
    That tranny is done. Burnt fluid in a GM Automatic = Toast
    Dave @ TripleEdgePerformance.com
    "The only sustainable competitive advantage is the ability to learn faster than the competition."
  7. #7 Re: Transmission slips bad at WOT
    Nov 2008
    ^ Dave is the MAN!
  8. #8 Re: Transmission slips bad at WOT
    SE Level Member 03impala9c1's Avatar
    Nov 2009
    Appleton WI
    sounds to me that that trans has about had it at this point. sounds like it could have started as torque converter/lockup issues and escalated from there. regardless... find yourself a gt trans, swap your hd dif and dif cover onto it put in the gt torque converter and mate it to a drilled l67 flexplate. you will thank yourself
    96 z/28 headers, cam, 3.73's, n2o, etc. - cant wait to bring her outta storage.
    99 gtp 3.0 nic l32 built trans and susp. sold
    99 regal gse t66 t3t04e zzp trans l32 stattama custom cam HUGE spearco a2a ic sold
    98 gtp 3.4 built susp sold
  9. #9 Re: Transmission slips bad at WOT
    Nov 2008
    Quote Originally Posted by 03impala9c1 View Post
    Oh yes... Yes you will
    Nothing like having a completely useless 1st gear at WOT haha. Wouldn't have it any other way
  10. #10 Re: Transmission slips bad at WOT
    Nov 2009
    Appleton WI
    Quote Originally Posted by ninnyGTP View Post
    It gets the chicks so lol
  11. #11 Re: Transmission slips bad at WOT
    Nov 2008
    Hey it's not called a GTP for nothing. "Gets The P*ssy"
  1. supercharger belt slips
    By neel2008 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2009, 09:31 AM
  2. help transmission whines and slips
    By joswo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-16-2009, 01:48 AM
  3. time slips
    By justwhisen in forum Forum Bugs/Suggestions
    Last Post: 05-14-2009, 11:07 PM
  4. tranny whins and slips help
    Last Post: 03-05-2009, 02:20 PM
  5. No 4th gear & slips/shacks at take off!
    By Stover in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2008, 12:13 PM
