Okay Guys, i just spent the afternoon slowly installing the TransGo Shift Kit and what can I say other than AMAZING!
I shifts perfectly now, be aware that i already have the pressure turned up w/ my TRIFECTA Tune so I didnt want something that was neck snapping... but like most others have reported, the car upshifts quick and efficently, like it did with the tune, and to be honest it was pretty good factory.
Downshifts are the huge surprise here though, it is amazing when going from 3rd gear to 1st! Almost instantaneously! Its smooth, fluent, responsive, and a number of other similar adjectives.
The install and fluid change wasnt bad either, this was my first time ever preforming a fluid change on a transmission but i am not opposed to getting greasy.
1) Pan drop was as simple as it gets... just tedious with the number of bolts.
2) Draining the fluid from the pan was pretty simple, just used the tips from other members and worked my way from one side to the other to make as little mess as possible.
3) I used the "How-To's" from a variety of sites to help make take the correct 4 bolts out to drop the accumulator.
4) The 3 metal lines were a little tricky, the shortest one was easy, but struggled a bit with the last 2.
5) The Transmission filter was a ***** to wiggle out with the oily hands.. but straight forward.
6) After dissemblance of the accumulator, and taking out the piston/springs, the directions that TEP provided were pretty easy to follow.
7) Hooking it all back up was easy and the car took 8 quarts of the fluid and was happy.
8) Took it for a spin around with a grin on my face
Thanks!
I'll update again once i get the cooler installed, going to do that one at my dad's place.
