Thread: having filling troubles
Results 1 to 8 of 8
  1. #1 having filling troubles
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    put in the 7.5 quarts for a pans drop with new filter. still at half mark on dip stick (between full and low) dip stick tube does have a crack, but it should still be filling, it doesnt seap that much.
    opinions?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: having filling troubles
    I had to do like 8 or 8.5 when i did my shift kit
    Quincy, Mass
    Are you checking after you drove around for a little bit so the trans has gone through all the gears and the car is still running?
    It's possible you were a little low before the drop. I too use 8-8.5 sometimes.
    No more GP 04 Impala SS Indy:
  4. #4 Re: having filling troubles
    is that at the cold mark or the hot mark. you want the cold mark as you just changed the fluid.
    warm the car up, by driving it some and re check it to see if its at full when hot.
  5. #5 Re: having filling troubles
    Pennsylvania
    I had to use like 8.5 qts, and I cant tell you how important level surface and having the car hot and running is.
    Sport Edition Kv5 18x8
  6. #6 Re: having filling troubles
    SE Level Member gwog's Avatar
    Feb 2010
    Georgia
    I am having the same issue. Will this thing hold 2 gallons after a fluid change? Last thing I want to do is over fill it. And yes checking it warm and have gone through the gears.
  7. #7 Re: having filling troubles
    The longer you let the trans pan stay off, the more fluid it will take.
    A quick pan drop, filter service usually takes 7-7.5 for me.
    A shift kit takes a bit more because you empty nearly another quart out of the accumulator and the pan is off longer.
    I once left my pan off for a week while swapping a diff. The trans took closer to 10 quarts that time around.
  8. #8 Re: having filling troubles
    Feb 2010
    Georgia
    Off for maybe a couple of hours. But seemed to be just a drip or 2 coming out when I got it back together. And no shift kit done, just a fluid filter change.
  1. Problem filling up at the gas pump?
    By jwjones in forum General Tech Discussion
    Last Post: 02-29-2012, 12:46 PM
  2. Filling Up takes 20 minutes...
    By White Cerebus in forum General Tech Discussion
    Last Post: 08-01-2011, 04:37 PM
  3. Proper Coolant Filling Procedure?
    By TronCarter in forum General Tech Discussion
    Last Post: 04-20-2010, 07:11 PM
  4. Fuel Leak While Filling Up
    By jshifti33 in forum General Tech Discussion
    Last Post: 04-05-2010, 08:44 AM
  5. Filling supercharger slits and egr.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2009, 08:52 AM
