Thread: trans issue on 02 monte carlo
Results 1 to 8 of 8
  1. #1 trans issue on 02 monte carlo
    Apr 2012
    santa fe new mexico
    Today it seams i have a major issue with my transmision. upon going to lunch my car had a hard shift from park to reverse. didnt think nothing of it, proceeded to head home and when i was leaving my house the car suddenly had no gears. car would rev not entirely freely but would rev with no movement. checked fluid level was a lil low not much but i added a lil with no change. tried all gears not a single one would move the vehicle. but if i rev it up a lil suddenly it would engage and jerk just momentarely but not stay? any ideas what could have gone out or possibly broke? trans was working fine til that hard shift from park to reverse!
  2. #2 Re: trans issue on 02 monte carlo
    St. Louis
    Possibly the forward band broke. Is the trans. whining at all? What color is the fluid? Wipe it on a clean WHITE rag to check for sure. Could be a clogged filter too.
  3. #3 Re: trans issue on 02 monte carlo
    Apr 2012
    santa fe new mexico
    checked fluid color is fine looks to be like a dark cherry color. and it does not move even in reverse. no real whine and it seams like the pump itself is working when the car is off the fluid level raises and when it is on the fluid goed to normal operating range so i guess i am rulling out the pump itself and maybe filter i do have a new filter in my toolbox that i can throw in it but i suspect it might be something else just not sure what... its just so odd cuz it happen just suddenly nothing was really happening that would throw a red flag so to speak.
  4. #4 Re: trans issue on 02 monte carlo
    Apr 2012
    santa fe new mexico
    Noticed something when i got my car towed to my work. When i start the car and the engine is runing if i shift to neutral the car wants to push forward even if i shift it to reverse it still has resistance pushing forward.
  5. #5 Re: trans issue on 02 monte carlo
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    Unplug the round connector at the top of the transmission and see if you get any movment, Assuming its a 4T65E. Sounds like what happened to me, and im in the process of swapping my trans right now.
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  6. #6 Re: trans issue on 02 monte carlo
    Apr 2012
    santa fe new mexico
    Quote Originally Posted by Brian99SE View Post
    I unplugged the round electrical conector and the car wont even start. at this point the trans has to come out regardless and i am at my work right now getting ready to drop the sub frame and asess it from there
  7. #7 Re: trans issue on 02 monte carlo
    If fluid isn't flowing...you won't have band engagement for any gear. Agreed on your assessment of the level and pump likely working. It's possible the input shaft broke, maybe the pcs stopped working. There is a port on the top of the trans that a pressure gauge can be hooked into.. when the car is running there should be pressure.
  8. #8 Re: trans issue on 02 monte carlo
    Apr 2012
    santa fe new mexico
    tore down the tranny and found out that the front planetary assembly was shot. looks like the bearing between the two main parts exploded and the needle bearings then took out the planetary assembly
  1. '96 Monte Carlo Z34
    By Condor120 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-29-2011, 07:34 AM
  2. about Monte Carlo trans?
    By Pure2sin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-10-2010, 10:50 PM
  3. monte carlo ss?
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 12-19-2009, 06:11 PM
