Thread: drive Shaft Question
Results 1 to 20 of 31
  1. #1 drive Shaft Question
    Aug 2011
    Orland, Me
    Hello,
    I'm about to replace the drive shafts and wheel bearings on my 2002 Gtp.
    What is the size of the nut on the outside by the wheel bearing? Also what is the torque spec?
    I know I don't have anything big enough to fit that.
  2. #2 Re: drive Shaft Question
    either 34 or 36 mm depending on if it's stock or aftermarket. Torque spec is really f-in tight lol
  3. #3 Re: drive Shaft Question
    Aug 2011
    Orland, Me
    It is stock so would that be the 36mm?
    I've seen 105 - 158 for torque.
  4. #4 Re: drive Shaft Question
    the new axle will be the different size bolt, bring your socket for the stock one and see if it fits before you leave the store, so you can buy the right size while you are still there.
  5. #5 Re: drive Shaft Question
    Antioch, IL
    156ft lbs.
    2009 Challenger SRT8
    Expert at being gay.
  6. #6 Re: drive Shaft Question
    Quote Originally Posted by ITHURTZ View Post
    156ft lbs.
    Wrong.
    It should be a 35mm for the axles nut, a 36 will work.
    Torque spec is 118 ft lbs.
  7. #7 Re: drive Shaft Question
    Aug 2011
    Orland, Me
    Thanks for the Info.
  8. #8 Re: drive Shaft Question
    Jul 2010
    Coquitlam,BC,Canada
    AllData shows 159 ft lb's. I used a 36mm socket to remove mine when I changed the bearings.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: drive Shaft Question
    Quote Originally Posted by Bronco Boy View Post
    Nope, look again.
    Search "axle nut" on alldata.
    Front Wheel Drive Shaft Nut (New) 118 ft.lb
  10. #10 Re: drive Shaft Question
    Delaware, OH
    Torque spec is German "guden tite"
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  11. #11 Re: drive Shaft Question
    Antioch, IL
    Nope, look again.
    well mine is 156
  12. #12 Re: drive Shaft Question
    Maybe in your head it is.
    But the REAL torque spec per GM is 118 ft lbs.
    Any other number than 118 is wrong.
  13. #13 Re: drive Shaft Question
    Minnesota
    Lol. It's 159 ft lbs in My version of Alldata too.
  14. #14 Re: drive Shaft Question
    Quote Originally Posted by Pure2sin View Post
    Wut?
    2002 Chevrolet Monte Carlo V6-3.8L VIN K
    Front Drive Shaft Nut 160 N.m (118 lb ft)
  15. #15 Re: drive Shaft Question
    Antioch, IL
    159 ftmfw! I need more indepth, why does four say this and alot of others say that. It CANT be for just ONE year
  16. #16 Re: drive Shaft Question
    Jul 2010
    Coquitlam,BC,Canada
    Nope, look again.
    Ok.
    Like this?
    Do as you wish, but 118 ft lbs is not enough for that nut.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: drive Shaft Question
    Omaha, NE
    Is noone going to address the difference between a drive shaft and a constant velocity axle?
  18. #18 Re: drive Shaft Question
    An FYI, the year 2001 is the only year that is 159 ft lbs.
    Why? Because GM is stupid.
    Then in 2002 boom, its back to 118.
    Hell even a 2009 Chevy Impala with a 3.9 v6, with the same control arms and trans and wb's and axles its 118 ft lbs.
    A 2000 GTP is the same as a 2001 GTP so the Torque spec of 118 is still going to be what it is.
  19. #19 Re: drive Shaft Question
    I like how bronco boy is using an outdated PROGRAM, other than a REAL time fully updated Alldatapro program via the Internet like me.
    Let me get a screen shot of what I am using.
  20. #20 Re: drive Shaft Question
    Here is my Proof that I am not lying and that what I am saying is 100% fact.
  1. 04 W-body trans question, output shaft
    By W30post in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2012, 08:51 AM
  2. Transaxel output shaft bearing and seal question
    By Tony48 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-24-2011, 01:13 PM
  3. Right hand drive question..PLEASE HELP!!
    By juicestain100 in forum Off Topic Discussion
    Last Post: 06-13-2010, 12:54 AM
  4. Final drive ratio question
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 08-11-2009, 05:58 PM
