Thread: Tim King transmission problem
Results 1 to 8 of 8
  1. #1 Tim King transmission problem
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    So I recently installed my brand new tim king transmission and I can't find reverse. When I do find reverse its in between park and reverse and every other gear is moved up one. Tim had me remove the round cap and see if the reverse servo was seated in the band right and that's all correct. My shift cable is correct and idk what else it could be. He's lost and so am I but he wants me to ship it back to take the side cover off and idk what to do because I can't afford all that when I just bought a new expensive transmission. Has anyone ever had this problem before?
    Polished Gen V, 3.1 mps, intercooled, S1X cam, northstar tb, and Tim King built trans with 3.29s and all the good stuff
  2. #2 Re: Tim King transmission problem
    Texas
    I have not, but my TK trans has like 8K on it and I don't don't drive my car very often. I know dallasneon had his crap out on him with about 12K on it.
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: Tim King transmission problem
    I know the problem.
    Let Tim know that you need a manual valve/manual valve rod combo that is correct. The problem for some guys when they have too many parts laying around (I learned this from experience) is that you can mix and match parts to build the best transmission. However some parts are different and the ATSG book, GM and all the other resources don't cull out that the parts are different.
    Here's the two different length manual valve rods
    And the two different length manual valves
    If you combine a long rod with a long valve, your valve is out of place. That's why your reverse is just far enough out of park for the parking pawl to be disengaged. Technically reverse would work in park if the pawl wasn't holding the transmission still. All your gears are off by one position on your shifter. Been there, done that, figures out how to fix it in the car.
    The reason you see the measurement on this parts case is because it's a painful less to have learned. This gives you the info you need to know the correct length fo the valve and rod.
    What you need to do is drain the fluid. Pull the side cover bolts and pop out the manual valve and or link. 2003 SSEi recently did this in the vehicle and may be able to add some tips. He said it was a pain due to the amount of space available. The other option is to lower that side of the cradle enough to pull the side cover off and then it's each to get at it. It's more involved though.
  4. #4 Re: Tim King transmission problem
    GTP Level Member
    Pittsburgh
    I had the EXACT same problem, Bill is correct
    2003 SSEi,
  5. #5 Re: Tim King transmission problem
    Bill told you what your issue was...lol
    Got any tips for this guy as to how to swap w/o dropping the cradle?
  6. #6 Re: Tim King transmission problem
    Keller,TX
    I just shipped my TK trans back yesterday. I haven't had the best of luck with this trans from the get go. When it was installed I had no reverse, called Tim and he had the shop remove the top cap and the reverse band wasn't seated properly, popped the band back on and it was fine for 12K miles. Tim took care of the cost for the shop to do that BTW. About a month ago the car started to shudder while trying to maintain any speed from 40-70mph, called Tim he said it was possibly the TCC solenoid valve, said it was cool to drive. Drove it for another week and then it felt like the TC was fully engaged all the time. Took it off the road, and pulled the trans a couple weekends ago. **** happens and Tim seems to be a stand up guy. Hopefully he can make it right for you.
  7. #7 Re: Tim King transmission problem
    menasha wisconsin
    Oh I defenetaly agree that **** happens for sure. This wasn't me ranting in a bad way I just wanna know a solution and seeing if people had any imput
  8. #8 Re: Tim King transmission problem
    Quote Originally Posted by RamonGTX View Post
    Issue identified
    Question answered
    Solution given
    We waiting on you Ramone.
    PS, if you or Tim need any of the parts, say the word. As you can see by the picture, there's a parts case with a bunch in there.
  1. transmission problem
    By jsucci in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2011, 04:59 PM
  2. Transmission Problem
    By cbeach in forum Introductions/Noob Questions
    Last Post: 12-30-2010, 08:23 PM
  3. Transmission problem?
    By The LoKi in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 12-19-2010, 02:43 PM
  4. Transmission problem
    By lhssnowman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-15-2009, 03:38 PM
  5. Odd transmission problem
    By ihartmacz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2009, 12:43 AM
