A 4T65 is a 4T65 for the most part. 03 is the oddball year. The other things that would be different would be the gear ratio. You'd want a vehicle with an NA motor so the drive/driven ratio is 1:1. Beyond that.. the ratio is due to the differential. Which ...if yours is good, can be swapped over.
