Thread: trans cross reference help
Results 1 to 4 of 4
  1. #1 trans cross reference help
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    ok ive got a 99 pontiac montana with the 3.4 motor and a 03 pontiac grand prix with the 3.1,they are both going to eventually need a transmission,the montana is going faster than exspected,ive heard that the 3.1 and 3.4 motors are the same,just the top end id different,would a trans out of a 3.1 fit a 3.4 and what years cross reference with the 99 3.4 and which cross reference with the 03 3.1 or in other words wich years of trans fit the 03 3.1 and 99 3.4,thanks
  2. #2 Re: trans cross reference help
    Not sure about the 3100 or the 3400...but I know the '03's are year specific with the 3800 4T65E's...so it would ONLY work in an '03 car unless you swapped the valve body and channel plate out.
  3. #3 Re: trans cross reference help
    Jul 2010
    ok so with the 03 it has to be a 03 with the 3.1
  4. #4 Re: trans cross reference help
    A 4T65 is a 4T65 for the most part. 03 is the oddball year. The other things that would be different would be the gear ratio. You'd want a vehicle with an NA motor so the drive/driven ratio is 1:1. Beyond that.. the ratio is due to the differential. Which ...if yours is good, can be swapped over.
  1. Boston acoustics or infinity reference 6.5
    By blakgtp in forum Audio, Security & Visual Electronics
    Last Post: 09-26-2011, 09:26 AM
  2. infinity kappa vs. reference
    By mezzoni in forum Audio, Security & Visual Electronics
    Last Post: 04-09-2011, 12:57 PM
  3. Can you limit power draw through smaller wire? (no, bad idea for reference)
    By nik12937 in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2010, 09:35 PM
  4. The Master Vehicle Bolt Pattern Reference Website!
    By jcrules78 in forum Tires & Wheels
    Last Post: 03-19-2010, 03:44 PM
