Thread: Trans problem...???!!
Results 1 to 20 of 22
  1. #1 Trans problem...???!!
    GTP Level Member
    springfield IL
    Ok ive been on the highway alot recently.... Noticed when i go to pass a car or to get on the highway, when i get on the gas the tranny doesnt down shift first.. Car just stays in the gear its in...?? Even at 4rpms.. Do i have a problem with my tranns..??!!
    Car is a 2000 grand prix GT. 130k ish miles
  2. #2 Re: Trans problem...???!!
    Dec 2011
    Philadelphia, PA
    so ur saying ur car has never downshifted when u hit the gas no matter what speed u floor it at?
    AEM bruteforce intake
    Diablo 93 Octane tune
  3. #3 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Quote Originally Posted by sLpGPGT View Post
    Yep pretty much.... Dont really drive it hard so i havent noticed till just recently..
  4. #4 Re: Trans problem...???!!
    When coming to a stop from any speeds, it downshifts normally?
  5. #5 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Ya doesnt do anything unnormal that i can notice.. All is smooth. I do notice when i take my foot off the gas and then go back to the gas u can hear something clank..??!! Not loud but u can really tell when ur driving around 30 - 50isg mph...
  6. #6 Re: Trans problem...???!!
    Apr 2009
    Fort Worth TX
    Have you changed the MAP sensor? Any DTC's?
  7. #7 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Quote Originally Posted by Rico View Post
    Nope on the map, did change the maf sensor last fall.... And that really brought up my mpgs!!! Lol
    No codes either... If tranny was bad would i see a service engine light..??
  8. #8 Re: Trans problem...???!!
    Apr 2009
    Fort Worth TX
    Let's see if anyone else has an opinion on the MAP sensor.
    Yea, a major problem may set a DTC. So you're saying you had the car scanned and they're are no DTC's; no CEL and no historic codes?
  9. #9 Re: Trans problem...???!!
    Here's the funny thing about DTC's that you notice when you start tuning or messing with the cars enough. Most transmission DTC's don't kick on the light. They set, the car might buck, scream and throw a tantrum...but those codes don't light up your life.
    Our up and down shifting is computer controlled. Therefore if you go up, you should be able to come down. Hence my question about it downshifting for stoplights etc. It does downshift,
    What rpm is 70mph driving normally for you?
    I'm starting to think that either you are in 3rd and the 4th clutch hub is shot, or you are having a sensor issue. Which.. my pal Rico has already eluded to.
  10. #10 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Rpms at 70mph are 2500 after awhile on the highway it does seem to back down to around 2300 after driving for a bit.
  11. #11 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Let's see if anyone else has an opinion on the MAP sensor.Yea, a major problem may set a DTC. So you're saying you had the car scanned and they're are no DTC's; no CEL and no historic codes?
    Only 2 codes ive ever had was a misfire..changed a coil pack and a maf problem..
  12. #12 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Anybody else wana chime in....??!!
  13. #13 Re: Trans problem...???!!
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by tc300 View Post
    So at 70mph you feel it slip into overdrive every once in a while? The PCM should command the TCC at about 55mph or so.
    If your RPM is around 1900-2100 at 60 mph then you should be in overdrive.
    If RPM is 2300-2500 at 60mph then you are stuck in 4th gear.
    Since there's no DTC then I would assume that the computer isn't commanding the TCC.
    This may be due to a vacuum leak or a bad MAP sensor. Vacuum and MAP sensor are integral to PCM for tranmission control.
    I hope the problem is a vacuum leak or a bad MAP and not the valve body in the transmission.
  14. #14 Re: Trans problem...???!!
    Chuck...he's a GT aka 3.29 gear ratio. His speeds etc sound about right for 4th TCC locked.
    Easy way to test TCC is holding your foot steady on the throttle at 70mph once it does that secondary drop down, Tap the brake pedal with your left, just enough to kick on the light. You should see the rpm jump 200-500 and then go back down a moment after the foot is removed from the brake pedal. That's the TCC disengaging and reengaging.
    To tell if you get 4th.. simply pull the gear selector to 3rd and see the rpm go up close to 1,000rpm.
    When you are doing 70mph and the car is sitting at about 2100-2300, if you stuff it to the floor, what rpm does it go to immediately?
  15. #15 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Yes every thing you said the car does correctly.... 2marow i will hit the highway and do 65 or 70 then floor it to see what the rpms go to. I know for a fact the car DOES NOT down shift first.. I hear a metal to metal when i take the car out park to back up and put it in drive.. A clank for reverse and a clank when put in drive. Gona try n see if i can record the sound. Maybe i can email it to you.
  16. #16 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Overdrive works 100% for sure... Just want to know why when i get on it, it doesnt down shift first...
    That is my question
  17. #17 Re: Trans problem...???!!
    Apr 2009
    Fort Worth TX
    What do you mean when you say "down shift first"? Are you saying that the down shift is delayed or it just doesn't down shift at all?
    I think that the PCM controls the transmission's "kickdown" via the TPS sensor. You could check the TPS output signal for smoothness and voltage. The best way to check transmission control is with a scanner. If the PCM is commanding TCC off and/or down shift to third when you mash it to the floor then there may be something wrong with the transmission internally.
  18. #18 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    When your driving dont most/all car down shift when u put the pedal to the floor..?? Every one i have drove did it, well besides my hyundai genesis and a old 350z i use to have cause they were sticks.... Lol
    When u mean scanner, are talkn the same one used for cel/ces lights...?? Or is there a whole different scanner??
  19. #19 Re: Trans problem...???!!
    Depending on what you used to get the engine codes, it may be able to scan the car in real time and see things.
    When you stuff a GP to the floor, it takes a moment, kinda bogs then downshifts and heads on down the road. It's not quite a perfect as say an old carb based motor with a true kick down cable that got the trans to downshift before the power kicked in. This is why manually downshifting if you plan on giving it a good blast on the highway is recommended. The 4th clutch hub in the 97-03's are weak and would usually suffer a failure when kicked at higher miles.
  20. #20 Re: Trans problem...???!!
    GTP Level Member
    springfield IL
    Ok are you saying my tranny is on its way of going out...???
  1. trans problem?
    By jim97regalgs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2012, 11:54 AM
  2. Trans problem. Please help!
    By stevenk8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2010, 02:18 AM
  3. Trans problem
    By Pontiac99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2009, 01:00 PM
  4. trans problem in a 00 gtp
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 05:16 PM
  5. 98 GT Trans Problem
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2008, 09:47 PM
