Thread: Transmission has a problem shiftin out of 1st...
Results 1 to 5 of 5
  1. #1 Transmission has a problem shiftin out of 1st...
    Riverview, Fl
    Transmission has a problem shiftin out of 1st...Any suggestions so I can fix it?
  2. #2 Re: Transmission has a problem shiftin out of 1st...
    Grand Rapids, MI
    Provide us some more details.
    I believe what you're trying to say is a slow 1-2 shift..? If so, that becomes common with age and lack of maintenance. you can read here about some common problems in case you're not referring to a slow shift... 4T65E Common Problems
  3. #3 Re: Transmission has a problem shiftin out of 1st...
    Riverview, Fl
    I changed the transmission filter and fluid about 2 yrs ago. It will most the time rev to 3500 rpms then you let off a little and it may (may)shift then. It has been getting worse and worse in the last mnth. I know one time I changed the filter cause it wouldnt move at all but this is different...
  4. #4 Re: Transmission has a problem shiftin out of 1st...
    If your filter was clogged two years ago and now you are getting slipping, I'd think you likely need a new trans. That's a guess though based on what sounds like an abusive relationship with your trans.
  5. #5 Re: Transmission has a problem shiftin out of 1st...
    GT Level Member GMCustomerService's Avatar
    Michigan
    masherima,
    Could you provide additional information? Is this a recent occurrence? Is it an intermittent issue? Have you had the vehicle inspected for this issue?
    Louis
    GM Customer Service
  1. Transmission Problem
    By rubent in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-14-2011, 10:34 AM
  2. Transmission Problem
    By cbeach in forum Introductions/Noob Questions
    Last Post: 12-30-2010, 08:23 PM
  3. Transmission problem?
    By The LoKi in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 12-19-2010, 02:43 PM
  4. Transmission problem
    By lhssnowman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-15-2009, 03:38 PM
  5. Odd transmission problem
    By ihartmacz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2009, 12:43 AM
