Thread: output shaft play?
Results 1 to 20 of 44
  1. #1 Re: output shaft play?
    Donating Users moddman's Avatar
    Midwest
    That's some planetary stuff from down in. That plastic piece is the lube dam and the splined shaft you have goes into the 3rd gear sprag.
    I have 2-3 transmissions laying around and those parts should be good, or ebay, maybe a trans shop. Likely though, most shops won't stock them because they are standard hard parts that typically don't go bad.
    What when wrong with them?
    Those parts were not from my trans. they were just based on info from my research of symptoms the car has. I just authorized a full rebuild happening in a couple of days. Let the fun begin.......
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  2. #2 Re: output shaft play?
    Midwest
    Quote Originally Posted by moddman View Post
    I picked up my car today......waited exactly 1.5 weeks for it to be fully rebuilt and installed. I drove it home about fifteen minutes and noticed right away.......no noise very quiet riding. So it seems justifiable that the previous noise was coming from in the trans. One thing I did notice is first gear shift is sluggish but it might be because everything is new and needs to be broken in. I have to drive it awhile before I say anything to the rebuilder. Other than that it shifts fine and the installed shift kit make the shift firm and crisp.
    3.4" ZZP MPS Pull
  1. 4t65 Output Shaft Stuck
    By Admiral Jedi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-02-2012, 08:22 AM
  2. Gun Drilled Output shaft
    By MidnightBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2011, 05:48 PM
  3. Output shaft questions?
    By johnsmith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2010, 07:58 PM
  4. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  5. Q? Output Shaft removal
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:07 AM
