Thread: no 4th gear a WOT please help
Results 1 to 20 of 35
  1. #1 no 4th gear a WOT please help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    at WOT it wont shift to 4th gear it just rides 3rd gear all the way to the red line and wont go any faster
  2. #2 Re: no 4th gear a WOT please help
    You don't want it to shift into 4th unless you have a built trans or you won't have 4th gear anymore after that.
  3. #3 Re: no 4th gear a WOT please help
    Portland Oregon
    Even with the hardened 4th hub you don't want to go into 4th at wot
  4. #4 Re: no 4th gear a WOT please help
    Why would you ever need to go that fast anyway?
    SE Level Member Milestone's Avatar
    May 2008
    It might be your tune. If i remember correctly ZZP has it so your car doesn't go into 4th at WOT so you won't kill your 4th gear.
    Sent from my DROID BIONIC using Tapatalk
    Modded.......Yes sir
  6. #6 Re: no 4th gear a WOT please help
    All I can say is, LOL.
  7. #7 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    dsmuts i was doing a top speed run, and you all arent making sense because ive done it before and its gone to 4th gear
  8. #8 Re: no 4th gear a WOT please help
    Do you have a scan with it doing this? If so.. look at commanded or current gear. See if it's telling the trans to shift or not. Then take a look at your shift tables to ensure nothing got swapped up in there.
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    Quote Originally Posted by asite57 View Post
    Maybe that's the problem
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  10. #10 Re: no 4th gear a WOT please help
    Please try and stay on topic guys. There's no need for a beatdown etc.
    I've done many WOT runs and it's the judgement of the guy doing it as to why. If the motor blows, it's his responsibility, if something else happens...it's his. We won't necessarily agree, but there's no need to sidetrack the topic.
  11. #11 Re: no 4th gear a WOT please help
    4th gear is a non hardened shaft and strips out quite easily that's why you shouldn't go wot to 4th and because its dangerous to go that fast.
  12. #12 Re: no 4th gear a WOT please help
    Kansas
    95mph and shift into 4th... I'm game.
    Back on track, like Bill said. It could be issues in your tune.
  13. #13 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    im gonna get it looked at i dont have a scan tool that good, now i understand WOT runs arent good for the car but there a lot of fun, how dangours is it for the car? thease engines are bulletproof but the trands im not so sure about
  14. #14 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    ive actually been reading around and what not i think my problem might be that im not getting 3rd gear in WOT
  15. #15 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    yup i have no 3rd gear at WOT what would cause this?
  16. #16 Re: no 4th gear a WOT please help
    what mph are you running? shift into 2nd should be around 50, shift into 3rd should be around 95, and shift into 4th I don't know because i've never done it. It's dangerous because if your shift into 4th at wot you'll be over 130 and chances are your tires are rated for it.
  17. #17 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    the 4T65E trans should shift from 2-3 durning WOT at 85mph which is around where my car is and then it just hits the red line also my tires are rated to 136+mph the car can do over 140mph
  18. #18 Re: no 4th gear a WOT please help
    Feb 2009
    flintnasty MI
    I go 60-140 in less than 7 seconds and I have never shifted into 4th.. You shouldnt either.
  19. #19 Re: no 4th gear a WOT please help
    the remedy is a another trans, i just lost 3 rd gear all together last month. used trans swap or a rebuild.
  20. #20 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    i know i know i thought it was no 4th gear but really it turned out to be im getting no 3rd gear at WOT and yeah i really hope it doesnt come to that
  1. Not going into gear at all
    By jwjones in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-18-2012, 04:58 AM
  2. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  3. no first gear what gives
    By blacksleeper in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2010, 07:49 PM
  4. top gear
    By 1999gt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-07-2009, 08:54 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
