Quote Originally Posted by grandprix5 View Post
ok well (smetimes) when im driving and do a complete stop the car goes to neutral for 3-5 sec after that the car goes into gear and everything its normal ! no issues after that but also sometimes when i turn to the right the tranny starts sliping like it goes into gear and then neutral -gear-neutral- until i go straigt but both issues happen only in some ocations not all the time and besides that the car runs fine in all gear shift points
abs/trac light on? or the low trac light flashing on? is the wheel spinning like when your getting on it on loose gravel? or just when you drive it normal does it slip or chatter?
almost seems like traction control is kicking in. vid maybe?
