Thread: Trans cooler lines, which is IN and which is OUT?
Results 1 to 20 of 24
  1. #1 Re: Trans cooler lines, which is IN and which is OUT?
    Oklahoma
    Okay, moved over to the 4T65E section.
  2. #2 Re: Trans cooler lines, which is IN and which is OUT?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Only the feed side or fitting point straight down has a checkball and this is only on SOME 99 and ALL 00+ cases until early 04. 97-some 99 cases do not have the checkball. IF your case has a fitting with a checkball then it must be retained. These cases will have a larger thread on the feed side than the return side. There are fittings that accept the threaded cooler lines that do have the checkball and will work in a quick connect fittings' place.
  1. SS fuel Lines
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2008, 01:02 AM
  2. Puffffffft...I can make that cheaper and cooler
    By GR8racingfool in forum Off Topic Discussion
    Last Post: 06-02-2008, 07:03 PM
