Thread: Won't shift into gear
Results 1 to 8 of 8
  1. #1 Won't shift into gear
    Oct 2011
    columbus ohio
    Hey everyone I am new to the site and have a question on my sons 1996 Grand Prix SE 3100. It will not go into gear when you shift it from park. Reverse lights come on, I can start it in neutral, no key issues. It just won't go. Every once in a while I can get it to go into drive if I play with it long enough. Reverse is impossible...
    Any thoughts? Thanks
  2. #2 Re: tranny help!!!
    trans most likely is bad.
  3. #3 Re: tranny help!!!
    Hagerstown,Md
  4. #4 Re: tranny help!!!
    Oct 2011
    columbus ohio
    Sometimes it will go into drive, once in drive it will drive fine. Easily shifts on road. Just won't go into gear without a LOT of working the shifter.
  5. #5 Re: tranny help!!!
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Sounds to me like something came loose. I had a new engine put in about a year ago which means they had to remove my trans, when they put it back in I was having problems with it not shifting when out of drive.
    apparently something was loose as the mechanic reached with a tool of some kind from the front of the car down to the trans and popped something back in. Trans has been fine ever since.
    I have a 97 gt so I am pretty sure its the same trans.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  6. #6 Re: tranny help!!!
    Hagerstown,Md
    Sounds like the safety switch that prevents it from going into gear without applying the brake
  7. #7 Re: Wont move in any gear
    Moved to the proper section.
  8. #8 Re: Won't shift into gear
    Oct 2011
    columbus ohio
    Would I be able to move the shifter if the NSS is bad? I can hear it click on the column. I removed the lower shroud on the column and the cable in the switch moves, don't know enough to know when they're good or bad. I also went to the yard and got two other positioning sensors and tried those but it didn't change anything.
    Thanks for the help!
  1. G6 tranny
    By qksilver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-12-2010, 02:44 AM
  2. Tranny and the PCM
    By offroadfury6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 10:29 PM
  3. FWD 3.8l to RWD tranny
    By static2489 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2008, 02:26 PM
  4. Tranny???
    By Darkcelle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2008, 10:36 AM
