Moved to the proper section.
Would I be able to move the shifter if the NSS is bad? I can hear it click on the column. I removed the lower shroud on the column and the cable in the switch moves, don't know enough to know when they're good or bad. I also went to the yard and got two other positioning sensors and tried those but it didn't change anything.
Thanks for the help!
