Thread: P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator errors
Results 1 to 17 of 17
  1. #1 P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator errors
    Jul 2008
    Steubenville, OH
    Hello this is my first post on here. So Im thanking all of you for any input on this problem. Here it goes............
    Im having transmission problems on my 2001 GP-se. First off its giving me these three error codes (P0753, P0758, P1860), 1-2 and 2-3 shift solenoid and TCC pulse width modulator errors. When you stick it in Drive and take off it starts out in 3rd gear instead of kicking down to 1st. When you pull it down into 1st it will only take off in 2nd gear, or while driving I can pull it form 2nd to 1st and it will not engage 1st gear ever. It will not kickdown while moving in drive if I step on the pedal to get it up a hill, I have to pull it down into 2nd to get it moving. I have checked voltage down to the trans housing on the harness connector. Im getting the proper 12 volts to pin E on the harness, and also checked the resistance of each solenoid on the transaxle case connector. 1-2 gets 23K, 2-3 gets 23K, and TCC is getting 12K, I have also Cleared these error codes after testing and they keep coming back. My routine to get the car moving consists putting shifter in 2nd then shift to third then I can here it shift to 4th but the convertor never feels like it locks up, I have to do this since if I leave it in drive it stays in 3rd. I looked at the ohms resistance chart and see that all three of my error codes are tied into pin E (pink) on the harness. 1-2 is A-E, 2-3 is B-E, TCC is T-E, I have checked there resistance by going through A-E for the 1-2. Im not sure if my 1-2 solenoid is stuck in 2nd or if I have a problem with my range selector. Im lost as of now and will be greatly appreciated of any knowledge I can pull from you guys/gals.
    Thanks,
    Josh
  2. #2 Re: P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator err
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Right off the bat I would suggest checking your fuse but you already verified 12v at pin E. Are you checking voltage here with the key ON and with a volt meter between Pin E and the battery or trans case? Check your grounds to assure they are tight on the stud which should be the front lower trans bellhousing bolt. Also the ohms checks you made on the solenoids should just be 23 ohms, not 23K ohms. You can try disconnecting the pcm connectors and checking the the shift and tcc solenoids right at the connector. With the key ON and pcm disconnected you should also see 12v on the other side of the solenoids at the pcm connector as long as it is disconnected. The voltage will flow through as there is no load and just an open end. This will verify for sure that there is a complete circuit between 12v+ and the pcm at the solenoids.
  3. #3 Re: P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator err
    Jul 2008
    Steubenville, OH
    I have verified 12 volts to pin E on the transaxle connector, also checked ground straps on the bellhousing. Im an f-body guy most of my LT1 Transam sensor's are in the thousands on resistance, this is why I said 23K instead of 23ohms so I know all the solenoids are testing correct. Im going to disconncect the harness from the PCM and check voltage up to the computer so I know Im getting a complete circuit. As soon as I type this up I will go test and reply back what I find.
    Thanks a million for the quick response Trannyman95, I actual stumbled across your website before I found this message board and it has been very helpfull to me.
    Josh
  4. #4 Re: P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator err
    Jul 2008
    Steubenville, OH
    Okay, 1-2 and 2-3 Noids are getting 12volts up to the PCM. I verified this by unhooking the PCM Harness then found my yellow-black, and light green wires that run to the noids and tested back to ground. I also restested from pin E (pink) to the PCM harness connectors and verified my resistance of each solenoid. Is maybe the PCM bad on this car not telling it to ground the circuit when it needs to shift? Im lost up to this point other than trying another PCM or any other advice that could help diagnose this.
    Also this keeps coming up -The PCM illuminates the malfunction indicator light control circuit P0650
    Thanks again,
    Josh
  5. #5 Re: P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator err
    Jul 2008
    Steubenville, OH
    I also took it on a test drive and when I pull the 10amp fuse to the pink 12volt source it experiences the exact same symptom as when I get good power up to the PCM.
  6. #6 Re: P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator err
    Fort Wayne, IN
    I you have or can get ahold of a different pcm I would try that first since everything looks ok up to the pcm connector.
  7. #7 Re: P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator err
    Hit a junkyard and find an older bonneville/Lesabre. They have a massive relay center right on the firewall. Trace back the fan wiring to the relays. Then take one of those relays and the wiring all the way to the fan.
    Makes a great weather protected relay that you can add a fuse on to power anything.
  1. Key Removal Solenoid
    By thermanlee in forum General Tech Discussion
    Last Post: 08-12-2012, 01:40 PM
  2. BBV solenoid wiring - L67 swappers please help
    By WillOverkill in forum General Tech Discussion
    Last Post: 04-10-2008, 07:15 PM
  3. ZZP Shift Kit
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-29-2008, 08:19 PM
  4. Getting a shift kit
    By ryangtp89 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 10:20 PM
  5. shift kit
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2008, 06:25 PM
