Thread: Rebuilt Trans in February - 3rd to 4th Gear Problems w hardened installed
Results 1 to 20 of 25
  1. #1 Re: Rebuilt Trans in February - 3rd to 4th Gear Problems w hardened installed
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    I don't have a scanner unfortunately and have never used one. I agree with you that a misfire would likely cause a DTC to come up (my usual mechanic said that as well). My misfire I had a while back was caused by a bad spark plug wire and it didn't throw a code either, but it was much less obvious/extreme than what I'm currently experiencing. The dealership said there were no tranny codes and the orig. tranny shop said that as well. The orig. tranny shop DID say, however, that he saw the check engine light come on and go off while he was test driving it up hills, but I've done plenty of hills (since the prob started) and haven't seen it come on once.
    I dropped the car off at another tranny shop this morning (they say they provide free diagnosis) and we'll see what they say.
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  2. #2 Re: Rebuilt Trans in February - 3rd to 4th Gear Problems w hardened installed
    Jan 1970
    Maquoketa, Iowa
    Bad misfires will cause the CEL to stay on. Moderate consecutive misfires may cause the CEL to blink.
  1. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  2. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
  3. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
  4. Security light flashes???
    By AKGTP in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 08:03 PM
