Thread: P0717 from trans. Lost 4th need help
Results 1 to 10 of 10
  1. #1 Re: P0717 from trans. Lost 4th need help
    Please tell us your year, model and mileage on the car. Then tell us at least the name on p0717. Otherwise it's time for us to all go google something that you've already looked up.
    Thanks.
  2. #2 Re: P0717 from trans. Lost 4th need help
    Looked it up.
    No input speed sensor signal. You said you checked the wiring from pcm to trans? Did you check the ohms or the trans to sensor? Search for me and trans info. in one of the links is the ohm reading you should get on each sensor/soleniod.
    4th may be the trans doing a limp mode or it may be a stripped out hub shaft.
  3. #3 Re: P0717 from trans. Lost 4th need help
    ontario
    it is a 2002 grand prix gt with the ssm90. 4t65e trans
    the mileage is 286000km original owner, well maintained
    code is P0717 - No/Low input/turbine speed sensor signal
    i checked continuity from the pcm plug to the 20-pin plug at the trans.
    i will do the search on your info and let you know
    Mike
  1. P0716 & p0717
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2011, 05:55 PM
  2. P0717
    By deadsnake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2010, 08:28 PM
  3. p0717, p0716, What fixes this
    By Jambat1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2010, 10:57 AM
  4. HELP lost 1st and 4th
    By davidl25 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2009, 05:42 AM
  5. lost
    By allenscott292002 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 07:09 AM
