Thread: Slips getting into first when cold, no shifting to 4th
Results 1 to 2 of 2
  1. #1 Slips getting into first when cold, no shifting to 4th
    SE Level Member mac507's Avatar
    Albany
    Hello,
    I just did an engine swap in my 00 GTP. The tranny was working perfectly before the engine swap. Now, with the new engine, it slips getting into first gear when the car is cold. Also, it will not shift into 4th. Is there a cable that needs to be adjusted or something else?
  2. #2 Re: Slips getting into first when cold, no shifting to 4th
    St. Louis
    No, no cable. It's all electronic. Have you checked the fluid level of the trans. at a full hot/idle? When was the filter/fluid changed last?
    Other than that I would go over the wiring harness and make sure you didn't leave something loose. Check the connections to the trans.
    Usually no 4th indicates a stripped 4th clutch hub. Does it try to engage OD at all? Notice any RPM spike when it should be catching OD and then falling back into 3rd?
  1. trans slips only the first drive per day
    By shawnheck03gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2010, 09:49 PM
  2. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  3. Transmission slips bad at WOT
    By Rather B Blown in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-13-2009, 07:08 AM
  4. time slips
    By justwhisen in forum Forum Bugs/Suggestions
    Last Post: 05-14-2009, 11:07 PM
  5. tranny whins and slips help
    By joswo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-05-2009, 02:20 PM
