Thread: transmission wont go into gear
Results 1 to 14 of 14
  1. #1 Re: transmission wont go into gear
    Apr 2011
    davenport ia
    the transmission never slipped, and I do not get any codes, it was acting like it was stuttering when the gas peddal was pressed on the interstate before it went out. I drove it on the interstate for 45 min then parked it at a freinds house, a couple hours later headed home, and only made it about a block before it went out.
  2. #2 Re: transmission wont go into gear
    SE Level Member 1bad3800's Avatar
    Jan 2009
    bensalem pa
    i am having the same proublem and every where i turn its a broken band in the trans that mean a complete rebuild but have you checked teh fluied and also try unpluging the plug on the bel houseing and see if it moves that should comend it 2 3rd gear and it should move but reve up alot ...
  3. #3 Re: transmission wont go into gear
    Your issue is not a broken band.
    A broken forward band will make it so that when the shifter is in D or 3 you will have no forward movement. Yet reverse and if you pull to 2 or 1 you'll have movement. Forward movement won't be normal, but it'll move.
    Losing all gears after a moment or minute is typically a clogged filter. Our transmissions run on hydraulics, without fluid to the various areas, they simply can't do anything. Hence the loss of all gears and when you turn it off..the material falls from the filter and then you can get moving again.
    Something like this could clog a filter
  1. Transmission wont reach fourth gear?
    By Bjm5295 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-23-2010, 07:18 PM
  2. 1st gear wont engage
    By dmcglynn in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2010, 02:30 PM
  3. Wont shift into 4th gear
    By youngmcse in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 05:23 AM
  4. Transmission Code and no 4th gear HELP
    By JunkboxGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 02:03 AM
  5. wont move in any gear
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 09:05 PM
