Thread: Problems with my transmission recently
Results 1 to 20 of 36
  1. #1 Problems with my transmission recently
    Minnesota
    The other day I was at the car wash and my friend owns it and he wasnt busy so I dropped my transmission pan to change out the fluid, and once it was all drained I figured that I washed out the pan, so I should wash out up inside, too, so while the pan was drying, I drove it up into the automatic wash with undercarriage and let it blast it all out, drove it out back of the car wash and just walked around to get all my stuff in the front, since I figured I shouldnt run it too long like that.
    So I reinstalled the pan and filled it all back up with dex 6, and then went to go home.
    It wont shift out of first gear, it gets up to 5k rpms when Im driving and starts to shake and shudder like the car is going to fall apart until I let off the gas and it slows down, it also makes this horrible grinding sound like 2 pieces of metal being forced together really hard once it begins to shake, but not always.
    Any help?
  2. #2 Re: Problems with my transmission recently
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Omg lmao Are you freaking serious?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Problems with my transmission recently
    Houston
    For Realz?
  4. #4 Re: Problems with my transmission recently
    Omaha, NE
    You might wanna start looking for a new transmission.
  5. #5 Re: Problems with my transmission recently
    GTX Level Member Confusingboat's Avatar
    Minnesota
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  6. #6 Re: Problems with my transmission recently
    Minnesota
    So you guys really think my transmission is shot?
    Isnt there any sort of fix for it?
    You guys seemed to diagnose and judge it pretty quickly, there has to be some kind of part that failed that can be replaced, isnt there?
    It was working great earlier in the day, we were even racing it on my empty back road...
  7. #7 Re: Problems with my transmission recently
    Minnesota
    P.S.
    2015 Evo MR
  8. #8 Re: Problems with my transmission recently
    Omaha, NE
    winning!
  9. #9 Re: Problems with my transmission recently
    Hagerstown,Md
    First off dumping chemicals like that into the drains is illegal, 2nd Why on earth would you think waters okay to get into there and okay to drive the car with the pan off
  10. #10 Re: Problems with my transmission recently
    Minnesota
    Well there was barely any left in there, I drained it all out... the fluid is in my drain container to take to the recycle place later this week.
    And it was only like 10 feet, it wasnt in drive that long... I was already literally outside the automatic wash while I was draining it.
    And my friend that is an expert at Autozone said it would be fine because the transmission would heat up and all the water would evaporate out anyways, and be displaced by the heavier transmission fluid.
    I didnt come here to be made fun of, I need help.
  11. #11 Re: Problems with my transmission recently
    Omaha, NE
    [QUOTE=Fast98GTPx;529821]
    QUOTE]
    Uhhh, no. Don't listen to autozone techs, EVER.
    You clearly didn't let anything dry and or "evaporate".
    Replace the trans and be done with it.
  12. #12 Re: Problems with my transmission recently
    Minnesota
    Quote Originally Posted by Fast98GTPx View Post
    You do realize you don't need any prior knowledge to work at Autozone right? What part of Minnesota are you from? I think I can help you out with the 20lb sledge I've got in the garage.
    Btw...
    2015 Evo MR
  13. #13 Re: Problems with my transmission recently
    Minnesota
    Why the hell are you guys reacting so strongly?
    It couldnt possibly hurt today's advanced transmissions to drive it less than 10 ft, I didnt even go over 1.5k rpms.
    I know you dont need any but he builds his own engines from scratch, he told me, so I know he knows.
    He told me I could just close it back up right after and it would boil off as I drive since it clearly gets hot enough to evaporate water in a working transmission... seems like common sense to me.
  14. #14 Re: Problems with my transmission recently
    Minnesota
    I'm seriously hoping your whole story is a joke dude. Cause that...that is ****ing ridiculous. I would look into buying a new transmission. Know how your gas cap for your tank says only unleaded fuel? Well...the same applies to transmissions. Transmission fluid only.
    You just destroyed that tranny like a seasoned pro.
    2015 Evo MR
  15. #15 Re: Problems with my transmission recently
    Hagerstown,Md
    lmao, Now I know your full of it
  16. #16 Re: Problems with my transmission recently
    Omaha, NE
    Overheat the trans you just lubricated with water, that sounds like a great idea right?
  17. #17 Re: Problems with my transmission recently
    Hagerstown,Md
    Yeah, and you see where it got you lol
  18. #18 Re: Problems with my transmission recently
    Minnesota
    Running a transmission without transmission fluid is like running an engine with no oil. It's just something you ****ing do not do, EVAR.
    2015 Evo MR
  19. #19 Re: Problems with my transmission recently
    Minnesota
    Ok, so let's say my friend was wrong and me getting some water in it is what is causing this acting up...
    How do I get the water out? Should I just drain the fluid and fill it back up again? That should let the water come out and evaporate and then I could put fresh fluid in again... then next time I wash it out I'll let it dry better.
  20. #20 Re: Problems with my transmission recently
    MY GOD MAN!!!! WERE YOU THINKING????????
    if this really happened i would pull the pan again and dump out all the nice new fluid back out replace the filter again, refill it, and fvcking start to pray.
    and dont ever put water in your trans again, or drive it dry again.
  1. Having some issues with our recently purchased car. Please help.
    By mngtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 05:45 PM
  2. Whats with gaming recently?
    By DaytonaGTP in forum The Rant Forum
    Last Post: 08-17-2010, 11:10 AM
  3. Got a new performance transmission built and installed, same problems occuring.
    By Lsick7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-19-2010, 05:00 PM
  4. Recently bought a 04 GT
    By Fubisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2009, 10:57 PM
  5. Transmission/ Coolant Flush Question and Problems
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 07-17-2009, 03:03 PM
