Thread: Trans Slips Between shift when in normal
Results 1 to 3 of 3
  1. #1 Trans Slips Between shift when in normal
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    Like the title states when driving with moderate throttle and without performance shift on it slips a little on shifts, but when performance shift is on it shifts perfect.
    just curious of any possibilities of what it could be oh and i changed the fluid and filter about 700 miles ago replaced with dex 6. i have 91k on it right now and this seems like it started once i changed my battery it seemed like all shifts in normal felt abnormally soft
  2. #2 Re: Trans Slips Between shift when in normal
    Mostly likely the pcm lost its memory on the adaptive shifts when the battery was changed. Theoretically it'll relearn and stop doing the slip. Although what it'll be doing likely is learning that you need increased pressure to engage the clutches.
  3. #3 Re: Trans Slips Between shift when in normal
    Jun 2010
    Beloit, WI
    thanks for your help makes me feel a little better about it
  1. trans slips only the first drive per day
    By shawnheck03gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2010, 09:49 PM
  2. trans slips off the line when warm
    By beezer34ca in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 11:00 PM
  3. GTP Trans won't shift to 4th after hill
    By SliceTheRice in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-11-2010, 10:37 AM
  4. Replies: 1
    Last Post: 09-23-2009, 06:05 PM
  5. What Trans Shift Points should I use?
    By Quicklynx in forum PCM Tuning
    Last Post: 10-25-2008, 08:04 PM
