View Poll Results: Gun Drilled output shaft
Voters
4. You may not vote on this poll
  • Worth the time/money?
    0 0%
  • Waste of time/money?
    4 100.00%
Thread: Gun Drilled Output shaft
Results 1 to 8 of 8
  1. #1 Gun Drilled Output shaft
    Banned
    Sioux Falls, SD
    Needing opnions on the gun drilled output shaft, looking at getting one wondering if its worth it or not? Its running me about $175. and that could go towards other go fast parts
  2. #2 Re: Gun Drilled Output shaft
    Grand Island, Nebraska
    Better safe than sorry? I dont have any experience with the part so i cant vote.
  3. #3 Re: Gun Drilled Output shaft
    I talked to Dave at one point. Another Bonneville friend Tommy Glover had one shatter on him.
    Of all the big builds I've seen, worked on and dealt with...not one had a problem with the stock output shaft. I abused the crap out of mine and it shows no signs of any issues at all.
  4. #4 Re: Gun Drilled Output shaft
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Um?? Ok I've tried to search Gun Drilled output shaft. Couldn't find anything thing on GPF. Not too many people know what a gun drill is. (in my experience anyway). But the only thing a gundrill does is put a long hole in a part. THAT'S IT. nothing special. So does removing material from a shaft make it stronger???? Link to this gun drilled shaft??? I can have an Engineer buddy take a look...
    Lambokit to be built!!!!!
  5. #5 Re: Gun Drilled Output shaft
    ZZ Performance
    Gun drilling gives us a 20% reduction in weight from the stock unit. Lighter components make your car faster and your transmission more reliable.
    ZZP output shafts are engineered so well that they come with a life time guarantee against breakage. The shaft can be replaced with the transmission still in the car, this means 1 hour install times!
    Funny thing is when one breaks the typical response on this "lifetime warranty" is that it was shocked by a burnout and best of luck.
  6. #6 Re: Gun Drilled Output shaft
    GTP Level Member
    Pittsburgh
    no not worth it, stock is fine
    2003 SSEi,
  7. #7 Re: Gun Drilled Output shaft
    Mercer, Pa
    Removing material on the I'd removes weight, it does not add strength. Removing material on I'd makes the part slightly weaker.
  8. #8 Re: Gun Drilled Output shaft
    Donating Users Tengis's Avatar
    Houston
    Id rather break a stock one that is easily removable then break an aftermarket one that explodes.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  1. 4t65 Output Shaft Stuck
    By Admiral Jedi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-02-2012, 08:22 AM
  2. Output shaft questions?
    By johnsmith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2010, 07:58 PM
  3. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  4. Q? Output Shaft removal
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:07 AM
