View Poll Results: Gun Drilled output shaft
Voters
4. You may not vote on this poll
  • Worth the time/money?
    0 0%
  • Waste of time/money?
    4 100.00%
Thread: Gun Drilled Output shaft
Results 1 to 8 of 8
  1. #1 Re: Gun Drilled Output shaft
    GTP Level Member
    Pittsburgh
    no not worth it, stock is fine
    2003 SSEi,
  2. #2 Re: Gun Drilled Output shaft
    Mercer, Pa
    Removing material on the I'd removes weight, it does not add strength. Removing material on I'd makes the part slightly weaker.
  1. 4t65 Output Shaft Stuck
    By Admiral Jedi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-02-2012, 08:22 AM
  2. Output shaft questions?
    By johnsmith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2010, 07:58 PM
  3. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  4. Q? Output Shaft removal
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:07 AM
