Thread: gf wants a gtp, i want technical infozz on trans problem!
Results 1 to 17 of 17
  1. #1 gf wants a gtp, i want technical infozz on trans problem!
    MA
    so as the title says my girlfriend is looking for a GTP. she found one that is very cheap, the guy told her that there are a couple issues one regarding the transmission. so i was talking to him today about it. in his words..
    " What i think it is. These cars come with a defective seal on the transmission. When you flush the trans after so many miles of it not being it ruins the seal. Which causes it to shift into neutral when you come to a stop, then back into first when you get on the gas." guy says it only happens every so often and only when warm
    it sounds convincing to me, but i know NOTHING of transmissions. so my questions are..
    is this a real problem?
    if so, what seal is it exactly and what kind of labor would be involved in changing it out?
    TIA guys
    SMGPFC Member #9
  2. #2 Re: gf wants a gtp, i want technical infozz on trans problem!
    MA
    ttt, id really appreciate the help..... this car will be such a steal if we get it...
    SMGPFC Member #9
  3. #3 Re: gf wants a gtp, i want technical infozz on trans problem!
    Pennsylvania
    Doesn't sound right to me [read: B.S.]. I have never heard of that before. You can call the guy on it easy, though. Replacing the pan gasket is cheap; just ask him to do that. If it fixes the problem, I'd be extremely surprised. Heck, even cheaper would be a free scan at an autoparts store. A shift as bad as he's relating would definitely throw a code.
    My honest opinion is that the transmission needs a rebuild.
  4. #4 Re: gf wants a gtp, i want technical infozz on trans problem!
    MA
    its not throwing any codes, the guy said he had it scanned.
    SMGPFC Member #9
  5. #5 Re: gf wants a gtp, i want technical infozz on trans problem!
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Quote Originally Posted by SilvaMan61 View Post
    I'd "test drive it" and put it thru some work and take it and get it scanned yourself so you know for sure.
    silver 2003 Grand Prix GT List is on it's way to be updated
  6. #6 Re: gf wants a gtp, i want technical infozz on trans problem!
    Scott...sounds like one of the valves in the valve body is either sloppy in it's bore or hanging up a bit. Take a look around Dave's site for the symptom.
    If that's what Dave or the symptoms suggest, pick up a redone VB/Channel plate off Dave along with a hardened 4th clutch hub and the few gaskets.
    I've got ripping the subframe and lowering the drivetrain to get the side cover off down to a science. Then it's a few bolts and the valve body/channel plate is out and we can drop in the new 4th hub, VB and channel plate, button it up and off ya go. Probably 4 hours with a helper if that.
  7. #7 Re: gf wants a gtp, i want technical infozz on trans problem!
    MA
    you mean 6 hours if im the helper lol. ill look at the site, your talking about TEP correct?
    SMGPFC Member #9
  8. #8 Re: gf wants a gtp, i want technical infozz on trans problem!
    Actually Scott. Call Dave, tell him I made you. he'll likely know this on off the top of his head.
    And no..with both of you helping.. 4 hours..
  9. #9 Re: gf wants a gtp, i want technical infozz on trans problem!
    MA
    alright ill give him a call
    SMGPFC Member #9
  10. #10 Re: gf wants a gtp, i want technical infozz on trans problem!
    Make the call...
  11. #11 Re: gf wants a gtp, i want technical infozz on trans problem!
    MA
    SMGPFC Member #9
  12. #12 Re: gf wants a gtp, i want technical infozz on trans problem!
    Jersey
    x2 on everything snorlax just said
    16' wrx sti- stock
  13. #13 Re: gf wants a gtp, i want technical infozz on trans problem!
    MA
    haha snorlax.
    SMGPFC Member #9
  14. #14 Re: gf wants a gtp, i want technical infozz on trans problem!
    SE Level Member IMPALADAKID's Avatar
    Dec 2010
    Dover, NH
    I have been told by more than one transmission builder that if a car has had the fluid flushed at regular intervals, that it would be ok to do so. But if the car has never had a flush, and has over 100k/8-10 years on it, introducing that much fresh fluid can damage the transmission due to the detergents in the fluid breaking down the old seals. The best route would be to take would be a pan drop with fresh filter, and top off with fresh fluid. If that does not fix it, it is time for a rebuild. So his story is very possible.
  15. #15 Re: gf wants a gtp, i want technical infozz on trans problem!
    Bill.. flush or pan drop service does not fix problems. It only changes fluid and puts a clean filter in the trans.
    Whatcha trying to fix buddy?
  16. #16 Re: gf wants a gtp, i want technical infozz on trans problem!
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    arrrrrrrrrrrrg not triena jack lol but . i notices somethingabout the valve body plate... i believe the tcc is behind that. its it a pita to change or no? anywrite ups. i thing my solinoids bad
    Smgpfc
  17. #17 Re: gf wants a gtp, i want technical infozz on trans problem!
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i not only ask dave but ask a couple of other trans shops
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  1. technical questions about stock radio
    By MrTube in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2010, 08:12 PM
  2. Trans problem
    By Pontiac99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2009, 01:00 PM
  3. Very Technical Speedo Question
    By xerxescct in forum General Tech Discussion
    Last Post: 07-15-2009, 04:19 AM
  4. New, but need technical help w/ SC
    By Subwarrior632 in forum Introductions/Noob Questions
    Last Post: 07-05-2009, 09:21 AM
  5. trans problem in a 00 gtp
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 05:16 PM
