ttt, id really appreciate the help..... this car will be such a steal if we get it...
Doesn't sound right to me [read: B.S.]. I have never heard of that before. You can call the guy on it easy, though. Replacing the pan gasket is cheap; just ask him to do that. If it fixes the problem, I'd be extremely surprised. Heck, even cheaper would be a free scan at an autoparts store. A shift as bad as he's relating would definitely throw a code.
My honest opinion is that the transmission needs a rebuild.
Scott...sounds like one of the valves in the valve body is either sloppy in it's bore or hanging up a bit. Take a look around Dave's site for the symptom.
If that's what Dave or the symptoms suggest, pick up a redone VB/Channel plate off Dave along with a hardened 4th clutch hub and the few gaskets.
I've got ripping the subframe and lowering the drivetrain to get the side cover off down to a science. Then it's a few bolts and the valve body/channel plate is out and we can drop in the new 4th hub, VB and channel plate, button it up and off ya go. Probably 4 hours with a helper if that.
Actually Scott. Call Dave, tell him I made you.he'll likely know this on off the top of his head.
And no..with both of you helping.. 4 hours..
