Thread: TC lockup/unlock problems? tranny rebuild ?'s trannyman step in!
Results 1 to 20 of 26
  1. #1 Re: TC lockup/unlock problems? tranny rebuild ?'s trannyman step in!
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Engine sensors can certainly have an impact on transmission operation, especially the MAF sensor, and going through a carwash could have picked up some a lot of extra moisture/water in the intake system depending on what you have on your car and can cause the maf sensor to read wrong. The pcm uses MAF signal to determine engine load based on airflow across the sensor and to some extent uses this information for line pressure, but at part throttle conditions it wont have near the effect as WOT conditions. While at very low throttle positions or shifting into gear the pcm has base pressures that it commands to do the job and it an engine sensor or wiring issue likely wouldnt cause slippage, though it could cause max line pressure which would give very harsh engagements into gear and during shifts.
  2. #2 Re: TC lockup/unlock problems? tranny rebuild ?'s trannyman step in!
    For S & G, try cleaning the ground wire connectors to the frame on both the driver's and passenger side. I've had some similar issues that were fixed by doing this. The electronics and sensors in the w body are very sensitive to poor grounds.
    It's worth a shot if it will band aid the problem until it's fixed; free is good.
  1. 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2013, 01:24 PM
  2. Tranny Tools Needed for Rebuild
    Last Post: 06-05-2008, 07:20 PM
  3. Tranny rebuild question
    By bula81069 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2008, 05:57 PM
  4. Lookie what I found in my tranny (Trannyman?)...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-23-2008, 01:00 PM
  5. Trannyman... need an aftermarket tranny dipstick...
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2008, 04:50 PM
