ok, so heres what it comes down to, if im rebuilding im going to upgrade in the process.
-Hardened 4th clutch hub
-Thrust washer kit
-All new solenoids and or a rebuilt/upgraded valve body
-New input sun gear
-Replace bands as needed, there are 3
besides these things, is there anything else i need?
would moving on to a higher stall convertter be worth it? will the car still be streetable? what would i have to do if i ever wanted to run slicks safely?
i also think im goign to replace the axles at the same time. if i do this, i will have replaced every single suspension and drivetrain part on the front end of my car, except the steering rack.
