Thread: shifting hard
Results 1 to 10 of 10
  1. #1 shifting hard
    Dec 2010
    Michigan
    just got done doing the head gaskets on my gp and the tranny is starting to shift hard.. i know a little about engines but next to nothing about transmissions.. it is shifting on time.. but rough
  2. #2 Re: shifting hard
    St. Louis
    What year/engine is your car? How many miles on it? Have you had it scanned for trans. codes? Is your trans fluid full? How's the color? (does it look brown/black or nice and red?) When was the last time the fluid/filter were changed?
  3. #3 Re: shifting hard
    GT Level Member donmega's Avatar
    St louis, mo
    need more info.....
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  4. #4 Re: shifting hard
    St. Louis
    ^This^
    Sorry, couldn't resist, lol... Stupid cold medicine
  5. #5 Re: shifting hard
    SE Level Member Paul79UF's Avatar
    Florida
    If you go somewhere to get it looked at, I'd recommend AAMCO.
    I had my tranny rebuilt at an AAMCO a few years and 30k miles ago. It runs like brand new. (It should for $2,800!)
  6. #6 Re: shifting hard
    New Brunswick
    Not sure how this would affect your year but on my 06 if the MAF sensor is disconnected it will shift hard for some wierd reason.
  7. #7 Re: shifting hard
    Dec 2010
    Michigan
    fluid is red and full.. but hasnt been flushed in a while..would that cause it to shift hard?
  8. #8 Re: shifting hard
    Since you pulled apart the top end. Double check maf and TPS. Those are the two sensors that effect the trans the most. Or go have it scanned to see what codes it has stored. Trans codes typically don't turn on a light, but they do store in memory.
  9. #9 Re: shifting hard
    St louis, mo
    maybe a shift solenoid as well pretty common problem but that would throw a code. do you have codes? yr and model? mileage? still need more info....
  10. #10 Re: shifting hard
    Dec 2010
    Michigan
    tranny flush seemed to solve the problem.. for now at least. we will see once
  1. Maybe shifting too hard?
    By Claude in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2010, 08:31 PM
  2. 2002 GP GT Hard shifting
    By bronzemist02 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2010, 01:26 PM
  3. Hard shifting and slipping?
    By Lonestargp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-15-2009, 11:56 PM
  4. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
  5. 2000 GT shifting really hard
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2009, 12:08 AM
