Thread: Input shaft broken??
Results 1 to 11 of 11
  1. #1 Input shaft broken??
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    Hey guys,
    I was out doing a WOT with my car, giving a buddy a ride and didnt even get through the first gear pull and SNAP! Lost all gears! I am assuming the input shaft has snapped. i have not tore into it yet. The car came this way with a stock trans...FML i know...But i do have a few questions....
    1. Can i replace the input shaft without removing the chain?
    2. I would guess i would need a new trq converter lockup ring?
    3. If the Input shaft is snapped how do most of you get them out?
    Sorry for such the newb questions.
    Just your normal 730whp 4dr family car.
  2. #2 Re: Input shaft broken??
    Charles City, IA
    Been a while since I have been in a 4t65, but The gears and chain should just lift off once you have the 4th gear clutches and hub out, then you should be able to take out the shaft, I could be way off tho, just going off a bad memory.
    SMGPFC Two Nipple General
  3. #3 Re: Input shaft broken??
    Dec 2008
    Sioux Falls,SD
    Is there a way i can leave the clutch in and just replace the shaft? Or does it all have to be pulled to replace the shaft?
  4. #4 Re: Input shaft broken??
    Charles City, IA
    they just lift off the hub.
  5. #5 Re: Input shaft broken??
    Jersey
    oh muy gawd, no wonder why it snapped
    16' wrx sti- stock
  6. #6 Re: Input shaft broken??
    Dec 2008
    Sioux Falls,SD
    Quote Originally Posted by 99prixgt View Post
    I know tell me about it!!!
  7. #7 Re: Input shaft broken??
    Portland Oregon
    The input shaft will have tone removed while the torque converter is off the car. The reason being is you have to remove the o-ring on the shaft to get it back out of the case. As far as the chains, they just lift off once you're down to that point.
  8. #8 Re: Input shaft broken??
    Dec 2008
    Sioux Falls,SD
    Quote Originally Posted by OH4CompG View Post
    Ok. Do you think its possible that the chain just broke? Or is it more than likely the input shaft? I still have Park if that tells you anything.
  9. #9 Re: Input shaft broken??
    n/a
    Its a possibility. You could have broke an axle or the diff. Do you still have park?
  10. #10 Re: Input shaft broken??
    Dec 2008
    Sioux Falls,SD
    Quote Originally Posted by billyimspeed View Post
    Yeah i still have park..
  11. #11 Re: Input shaft broken??
    If its not leaking fluid I highly doubt its a Diff that shrapnel has to go somewhere!!
  1. Broken input shaft? help please... Trannyman?
    By carfreak967 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2009, 12:56 PM
  2. intense input shaft
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2008, 02:54 PM
