Been a while since I have been in a 4t65, but The gears and chain should just lift off once you have the 4th gear clutches and hub out, then you should be able to take out the shaft, I could be way off tho, just going off a bad memory.
Is there a way i can leave the clutch in and just replace the shaft? Or does it all have to be pulled to replace the shaft?
