Thread: engine rattle on cold start up
Results 1 to 12 of 12
  1. #1 engine rattle on cold start up
    Jul 2010
    bettendorf ia
    i got my gp a few days ago. then today i started it up its not really cold out but it sat overnight. it was rattling like hell. slowley got quiet took about 5-6 mins to go away. sounds like its between supercharger and back of the motor. after 6 mins it didnt make the sound again.
  2. #2 Re: engine rattle on cold start up
    Jul 2010
    bettendorf ia
    this was in park the whole time and its a 03 with 50k
  3. #3 Re: engine rattle on cold start up
    Apr 2009
    stockton ca
    Sticky lifters altho thats not a rattle sound
    weird
  4. #4 Re: engine rattle on cold start up
    Jul 2010
    bettendorf ia
    does that make a click sound? it had somewhat of a click sound too. whats the lifter solution replace them?
  5. #5 Re: engine rattle on cold start up
    Apr 2009
    stockton ca
    1/3 can seafoam in the oil and run it 50-100 miles
    then change oil
  6. #6 Re: engine rattle on cold start up
    Jul 2010
    bettendorf ia
    thanks i will try it. i let the car sit about 6 hrs and started it back up and it was making the same noise.
  7. #7 Re: engine rattle on cold start up
    SE Level Member reddog's Avatar
    Jul 2010
    Canada
    What exactly will seafoam do?
    1998 GTP Stock 2004 GTP Stock
  8. #8 Re: engine rattle on cold start up
    Jul 2010
    bettendorf ia
    acording to the bottle it frees sticking lifters
  9. #9 Re: engine rattle on cold start up
    Jul 2010
    bettendorf ia
    started up today clicking like hell from back valve cover. sloweley went away after 6 mins it was gone.
  10. #10 Re: engine rattle on cold start up
    Jul 2010
    bettendorf ia
    just thought i would update that the pontiac dealer replaced all lifters pushrods and rockers
    03 pontiac grand prix gtp limited edition
    02 chevy silverado 4x4
    97 pontiac sunfire
    87 ford mustang notch 408 stroker
  11. #11 Re: engine rattle on cold start up
    Nov 2010
    Atlanta Ga
    Wow, buisness must be really slow for them! Did they charge you to replace everything?
  12. #12 Re: engine rattle on cold start up
    Wichita, KS
    Could just be the lifters needing to be pumped up with oil, when its very cold out, the oil is thicker so to say, and takes a little while longer to circulate, this is normal.
    Could also be piston slap form the piston skirts, as soon as the pistons warm up and expand, this stops. Normal.
    Could also be the supercharger rotors, same thing, once they warm up they will expand and quiet down. Normal.
    Or...you had a collapsed lifter or two, this happens as well.
    ~F~
  1. cold start smoke
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 09:42 PM
  2. Cold Start Hissing
    By SuperSport in forum General Tech Discussion
    Last Post: 07-24-2009, 12:56 PM
  3. Cold Start Injectors
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 01:20 AM
  4. Cold temp no start
    By mph68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 09:09 AM
  5. Engine rattle at 2100 RPM
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 03:29 PM
