Thread: Burnt smell from the transmission fluid?
Results 1 to 8 of 8
  1. #1 Burnt smell from the transmission fluid?
    Jun 2010
    Portage, Mi
    I check my trans fluid and it has a burnt smell. Is this something I should be worried about? It hasn't been shifting weird or anything so thats good I guess...The car only has 111,170 miles on it..I'm thinking I should get the fluid and filter changed.
  2. #2 Re: Burnt smell from the transmission fluid?
    yea, the fluid has been used well. Just change the filter and fluid.
  3. #3 Re: Burnt smell from the transmission fluid?
    Jun 2010
    Portage, Mi
    Cool thanks man...
  4. #4 Re: Burnt smell from the transmission fluid?
    Portland Oregon
    Since you're pan dropping it's a good time to switch to dex 6
  5. #5 Re: Burnt smell from the transmission fluid?
    Jun 2010
    Portage, Mi
    Quote Originally Posted by OH4CompG View Post
    Whats Dex 6? And whats the difference between a normal trans and a hd trans? I mean I know it means Heavy Duty but can a normal trans be converted to an hd or do u have to find a hd trans and mod it to fit?
  6. #6 Re: Burnt smell from the transmission fluid?
    Portland Oregon
    The HD trans has a stronger differential. It is also bigger so you'll need the HD diff, the diff cover, and an HD axle. Some say you'll need the output shaft from the HD trans but I never used one on my impala when I swapped it and it clicked in place and worked just fine. And as far as the fluid goes, Dexron 6 is a newer standard fluid that is now factory fill in GM vehicles. I think it's a synthetic blend of some times but better for your trans.
  7. #7 Re: Burnt smell from the transmission fluid?
    Jun 2010
    Portage, Mi
    OK good deal I'll ask about it....I know eventually I will have to rebuild the trans, because I had to get the trans rebuilt in my 2000 Buick Lesabre and I was told that the trans in the grand prix is the same thing and because of the metal used in the fourth gear start to break down and send fragments through the trans. It cost me 1300.00 to have it done.
  8. #8 Re: Burnt smell from the transmission fluid?
    If it cost you 1300.00 for that fix, you might want to look at TEP transmissions the next time around. They are very heavy duty and cost around the 1500.
  1. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  2. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
  3. Transmision fluid burnt. Do i flush it?
    By joshb227 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 09:13 PM
  4. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
