Hey all,
The easiest way to explain this is by having you watch a short clip on YouTube. Video is titled :
Pontiac Grand Prix GTP - Busted / Broken Transmission
Just curious if I should just go with an overhaul or by chance is it isolated to just the solenoid packs. After it slipped and chattered I "gently" went through the gears manually and they are all still there but it is starting to surge and slip at 60 mph.
The tranny first slipped when I went full throttle from a rolling start at around 20mph. It downshifted to first loaded up for a split second and then totally disengaged in my opinion there almost seemed to be no clutching at all. No warning lights flashed at all.
I drove for another 10 miles babying it and everything was quiet. After that it slipped at 3000 rpm and made that terrible skipping ratcheting "snap" when I half throttled up a hill to get home. Amazingly enough it is still drivable and oddly there is no metal in the fluid yet. Any suggestions would be appreciated.
Thanks in advance, Jeremy
