Thread: 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
Results 1 to 20 of 45
  1. #1 Re: 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Trannyman
    I want to make sure I have no valve body issues down the road as I understand a lot of people seem to have issues when they get higher mileage. What would you replace in the valve body:
    All 4 sensors
    Upgraded Boost valve
    Upgraded TC valve
    Ect:
    I don't have the tranny experience that you have to know what I should do and what I shouldn't do because its over kill.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  2. #2 Re: 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I always replace all 4 solenoids during a rebuild regardless of the history of them. Its worth the small extra cost to cover your back here instead of a month after the trans is back in the car have a solenoid crap out and then look at all of the labor involved! Its just foolish in my eyes to gamble some something like solenoids. There are companies with actual valve body testing machines that will run warm trans fluid through and test the functionality of the valve body and solenoids and if that checks ok then they are probably safe to reuse. A lot of aftermarket reman valve body companies do this and it is perfectly fine. Most guys dont have a $50K machine to do this so replacing the solenoids is the best and safest option. I also upgrade the boost valve with one the comes in the Transgo kit, or if not using that one then a Sonnax boost valve goes in. The I replace both the TCC switch valve and regulated apply valves. Most 98+ valve bodies have hard anodized valves, dark in color, and they seem to hold up pretty well and not wear like the earlier ones but the valve body bores still wear and cause problems. On the 97-mid 00 valve bodies there are forward and reverse servo boost valves and I like replacing as a minimal the forward one with a Sonnax valve to make sure the forward band has good solid apply. Something else to make sure you check out is the pressure switch manifold. This can be tested with an ohm meter or one that tests continuity and half of the switches are normally open while the other half are normally closed. After that is verified and the assembly is good I replace all of the oring seals on the switches. New ones are included in the gasket kit. There are other valves that can be replaced but I just never has seen the necessitiy of them. If the valve body is in that bad of shape and cant be cleaned up then its best to replace it.
  3. #3 Re: 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    Schaumburg, IL
    I thought the transgo shift kit just has springs and spacers that go into the accumulator. I installed the wbody shift kit about 1.5 years ago and I'm going to remove that and install the transgo in its place. So your saying that the trango kit has more than just springs and spacers in it?
  4. #4 Re: 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    Schaumburg, IL
    I was just happy posts weren't disappearing like clubgp
  5. #5 Re: 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    Fort Wayne, IN
    LOL I feel ya on that note!
  6. #6 Re: 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    Schaumburg, IL
    I've noticed in my trans it occasionally shudders in drive when I take off. It almost feels like wheel hop but I'm convinced its the trans. Trans has 70k on it right now and it happens probably less than 5% of the time. It occurs most often at like 30% or so of take off power. If I mash the gas it just breaks the tires loose. But if I decide to accelerate a bit quick it does this.
    What are the likely areas of concern. I have a wbody shift kit with DHP 1.5 bin file which is currently not been modified. I have a snap on scanner so I can read a bunch of trans data if necessary. No trans codes as of right now.
  7. #7 Re: 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    Schaumburg, IL
    So I was going through my ATSG update book and it mentions the PCS is likely the culprit which I've heard is notorious for going bad in our trans.
    Trannyman
    It says in the update book that prior to installation, you should turn the New Desgin PCS (OEM # 10478146) adjusting screw an 1/8 turn, as well as installing the Boost valve sleeve kit (Sonnax #84754-30k). Do you typically turn the adjusting screw in the new PCS or do you just install the new one along with the boost sleeve kit.
  1. Thanks to Trannyman95
    By 02BlueGT in forum Shops and Community Heroes
    Last Post: 08-24-2008, 07:35 AM
  2. Clutches for 4T65E-HD rebuild: BW, Raybestos, or Alto Red Eagle (or other)?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2008, 10:04 AM
  3. Tranny rebuild question
    By bula81069 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2008, 05:57 PM
  4. Trannyman95 twin charged info?
    By ebk231 in forum Off Topic Discussion
    Last Post: 12-17-2007, 04:30 PM
