Thread: Trany shifts Hard down but easy up
Results 1 to 6 of 6
  1. #1 Re: Trany shifts Hard down but easy up
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I had the fluid changed when I bought the car All levels are correct
    ANd I am not sure if the car had been modded or not the Engine still looks like you could eat off of it. A shift kit was the first thing I thought of but that should shift hard up and down no??
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: Trany shifts Hard down but easy up
    Naugatuck CT
    Has anyone eles see this
  3. #3 Re: Trany shifts Hard down but easy up
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Without knowing anything about the car it is hard to say if a problem was built into it to cause this. If you have an aftermarket reprogrammed pcm then this makes sense as you shouldnt have a harsh downshift from 40mph which you are likely dropping back into 1st gear which was common on older aftermarket pcms. A stock pcm will not allow a kickdown into 1st gear at that speed. What are your full throttle upshift rpms at? If they are at around 5800 rpm then you have an aftermarket pcm your shift points will be this high, stock ones are set at around 5400 but often shift at 5600. If the pcm is stock then you could be having some trans problems such as worn clutches or some valve body problems.
  4. #4 Re: Trany shifts Hard down but easy up
    Naugatuck CT
    thanks I will check the up shift tonigt and see
  1. Shifts are pretty hard...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2008, 11:13 AM
  2. Need help spending some money (This should be easy)
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2008, 01:02 PM
  3. Easy Dent Removal
    By SyntheticShield in forum Visual/Body Modifications
    Last Post: 04-04-2008, 05:17 PM
  4. Trany whines....I think
    By evlprx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2008, 01:14 PM
  5. So I found an easy how to on carbon fiber panels
    By s1795so2 in forum Visual/Body Modifications
    Last Post: 01-22-2008, 05:13 PM
