I have this weird symptom with my tranny. At around 50 mph i'll be in 4th gear and i'll press the gas down lightly, just far enough for it to kick into 3rd at about 3,000-3,500 RPMs and it feels like it slips a little bit goin into gear. Like when you go to accelerate in 4th gear and it starts to bog so you press it down a little bit more...that's when it does it. Also feels like it kind of pops into gear. It doesn't do it at higher speeds though, or lower speeds. Just between like 47 and 53 mph. This started happening right after i put my custom tuned Overkill PCM in too. Could it be something with the PCM and how the tranny tables have been modified? And another thing...i just found out that one of my cooling lines is leeking and the trans was about 1 pint low on fluid. I did put more fluid in. Have any ideas? Thanks.
P.S Has got acquainted with the girl, http://cyberblady.com, how it to you? Only it is fair!
