Trannyman95
I would check with a scan tool to make sure you dont have code P0826 in the code history or present codes list. The Tapshift signal from each paddle switch goes directly to the pcm and share the same wire. I did have a customer not too long ago run into a similar problem, though there were other problems as well that he noticed, but the tapshift function would not work. Cruise control also would not work and the compass in the driver info center kept saying it needed recalibrated. The cause was a blown Cruise fuse in the underhood fuse/relay box due to something else aftermarket being added to that circuit. The trans worked ok in D mode though it has harsh shifts. I would check the fuse first to make sure it is ok and not causing your side effects. The pcm is in control and as long as it is getting the correct signals from the trans internal mode switch and tapshift paddles then there isnt much left to point at. Since it sounds like this problem happened immediately before the old trans failed I would say the new trans is not causing your problem and its operation is just result of what happened before it was installed when you were limping along the old trans.
