Just replaced the radiator, and am getting leaks in the oil cooling lines at the radiator. I have pulled the lines, and checked the o-rings, and then retightened them. They are still leaking. I used the new fittings that came with the radiator. What's the trick here?
Also..........I think I may have stripped the threads where the top hose fitting goes into the radiator. Can you replace the threaded piece in the radiator without buying a whole new radiator? It comes out, but I cannot find just that piece online. If the answer on this is "no", I guess I'll just install an auxillary cooler, and leave the radiator alone.
