Didi the radiator you get have push in type quick connect fittings in them? If they did and you removed the fittings yourself then when you try to use your threaded cooler lines it will not seal properly due to the inner cone of the fittings being different than the cooler lines. I had to convert mine to the newer style quick connect lines to get it to work.
