Thread: Tranny whine after diff and diff case replace...
Results 1 to 20 of 20
  1. #1 Tranny whine after diff and diff case replace...
    Donating Users Tengis's Avatar
    Houston
    ... title says it all!
    It whines in park, neutral, and the gears. Most noticable when Im not moving (only because there is no other noises) but it does make a noise for sure.
    Also, my transmission seems to be heating up a little bit (although I did do some WOT runs after driving around for 15-20 minutes and checking fluid level). My engine temp was at 185 and my tranny temp was 199-200ish. I could just be paranoid about the temp.
    I changed the fluid to Dexron VI. The whine appears to be coming from the RIGHT side of the transmission (when standing in front of the car and opening the throttle blade).
    I do have a TAD too much fluid in there I think... but Im not 100% positive. Im going to drive it around tomorrow after the fluid settles. Could a bit too much fluid cause extra heat and a whine?
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  2. #2 Re: Tranny whine after diff and diff case replace...
    Houston
    Also, Ive had this issue but it might be related to my stall:
    When I am driving in second/third... if I let off of the gas and coast, and then hit the gas again... I can feel the gear "grab" after a split second of reving. I would probably think its my 2500 stall since it grabs right below 2500 rpm. Thoughts? *shrug*
    Satin Purple 97 GTP
  3. #3 Re: Tranny whine after diff and diff case replace...
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Did it whine like this at all before you swapped the diff? The diff end of the trans does not spin while sitting still so your noise is either further into the center of the trans or even a pulley on the engine which I have heard many that sound like trans noise but isnt. You can buy a cheap stethoscope from most auto parts stores so it may not be a bad idea to pick up one and have the car running while jacked up and lay under it and listen across the length of the trans to pinpoint where it is coming from. MAKE SURE THE CAR IS SECURE ON STANDS OR RAMPS!!!!!!!!!!
  4. #4 Re: Tranny whine after diff and diff case replace...
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    if you dont have a stethoscope handy, a piece of rubber hose/fuel line will work if needed...
  5. #5 Re: Tranny whine after diff and diff case replace...
    Barksdale AFB, LA
    Quote Originally Posted by Toasty View Post
    Just remove the fuel first.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Tranny whine after diff and diff case replace...
    Houston
    The noise seems to most certainly be coming from the tranny IMO. It is not a pulley or anything... it is coming from the side of the motor the throttle body is on.
    Satin Purple 97 GTP
  7. #7 Re: Tranny whine after diff and diff case replace...
    Fort Wayne, IN
    I may need refreshed on everything with you car, but did the noise happen after the diff was swapped, and I mean like you drove it a short time and then the noise came on? I would check for codes and see if you have one for incorrect ratio or max adapt shift. There are a handful of causes for noise on the converter side of the trans and they are mainly bearing noises, but since you mention the noise didnt occur until AFTER the diff work then it could be the pcm commanding max line pressure which will cause the pump to whine.
  8. #8 Re: Tranny whine after diff and diff case replace...
    Houston
    It did not whine before the diff was swapped.
    I ended up swapping the diff and putting on the diff case slight ajar or some **** (dont know what happened) and it cracked and started dripping. I took it off and put it back on in such a way so that it wouldnt drip until I got a new diff case.
    Put new diff case on a week later. At this point, my tranny is maybe 2 quarts to 3 quarts low. I put in a quart and start the car. I hear the whining. I put in another quart... it seems to quiet down a little. I check fluid and its still low... so I put in another quart. Its right up to the max point.
    Im not throwing any codes and my car seems to be shifting fine through all gears.
    Satin Purple 97 GTP
  9. #9 Re: Tranny whine after diff and diff case replace...
    Houston
    I noticed today I also get this weird mechanical whirring noise when Im decelerating... although this could totally be my imagination since Im paranoid about it whining. Its not whining at a very audible level anymore, but I can still hear it when I couldnt before.
    Satin Purple 97 GTP
  10. #10 Re: Tranny whine after diff and diff case replace...
    Fort Wayne, IN
    Did you check the bearing that goes behind the park gear to make sure it is seated properly before you tightened down the housing? If you damaged anything in that area you may have created a new problem. The trans shouldnt whine from being a few quarts low. It may but it really shouldnt, especially after you topped it off.
  11. #11 Re: Tranny whine after diff and diff case replace...
    Houston
    Park gear was fine, I pushed it back after I checked the bearing the first time and it never moved after I put it back. Regardless, I had one side covered in vasaline to make sure it sticks there...
    I was under the impression the bearing wouldve kept everything from coming together if it fell?
    Also, something I just thought of, my fluid was pretty damn dirty for a tranny with 10k on it. Maybe all of the material in my fluid was keeping something from whining while the cleaner fluid isnt? I have no idea, so Im totally geussing...
    Satin Purple 97 GTP
  12. #12 Re: Tranny whine after diff and diff case replace...
    often time noise on deceleration is bearing related, especially with rear wheel drive vehicles with diff beairing going out, but we aren't dealing with a rear wheel drive vehicle. You say the noise wasn't present before you did the diff swap? What were you trying to accomplish in doing the diff swap? While you are in park a lot of things are still rotating in the transmission, none of them are the park paul or differential, so if you are hearing the noise in park, you can rule out your diff. Ten thousand origianal miles seems too soon for a bearing or torque converter to go bad, but anything is possible. Were you having trouble with the shaft that splines onto the park pawl and diff sun gear when you were reasembling? How far of a gap did you have between the diff cover and case before you tightened the bolts?
  13. #13 Re: Tranny whine after diff and diff case replace...
    SE Level Member JCGT's Avatar
    Central, NJ
    May sound stupid, but I had a similar issue and it was my AC compressor clutch going bad. Sound varied with engine speed, and it happened in all gears. Try turning the AC on and seeing if it goes away.
    12.83@107.75mph 1.93 60' street tires
  14. #14 Re: Tranny whine after diff and diff case replace...
    Maybe some good info here maybe not. I just had a oldmobile silohette show up in to my shop. It may have been a 60 and not a 65 e, but that doesn't matter in this situation. Anyway they just had their trans "serviced" by a pep boys and ever since then they noticed a noise and it was at low speeds like in a parking lot that they heard it. I told them it was most likely unrelated, but decided I should further investigate. Turns out they didn't service it they just did a flush or maybe did a flush I don't know basically the pan wasn't off. Checked the fluid level... barely touched the stick and it was warm. I told them it was low but not enough to be of concearn... boy was I wrong. We agreed to fill it till it got to proper level and document it for whatever reason we need it for. Three qts!!!! It took 3 qts and it registered on the stick before I put the 3 qts in. Also the noise went away, and i had the customer drive it to verify it. It sounded as if the chain was rubbing when I heard the noise initially... almost like a can of marbles rolling around.
  15. #15 Re: Tranny whine after diff and diff case replace...
    Houston
    Can too much fluid cause an issue? How much is too much? Over the max line? Mine might be a tad over full. Ill check the fluid level in the morning when I get to work after its had time to warm up.
    Satin Purple 97 GTP
  16. #16 Re: Tranny whine after diff and diff case replace...
    Hoffman/Schaumburg, IL
    I could see too much causing a noise, Like the hard parts whipping it up, but that would be way overfull I would think... Hopefully someone who knows more will chime in
  17. #17 Re: Tranny whine after diff and diff case replace...
    Houston
    Alright, new update. My tranny is slowly sucking down fluid. I just added a quart and it topped it off... and the noise Ive been hearind went away. I checked the dipstick when I got to work and it was a quart or so low.
    Is that normal for the tranny to appear full and then it "seeps" into all of the nooks and cranies over a day or so? The whine went away, but there is stll this other unknown whine I cant even explain =p.
    hah...
    Satin Purple 97 GTP
  18. #18 Re: Tranny whine after diff and diff case replace...
    Being overfull of fluid will cause your fluid to airrate and act is if you aren't picking up fluid since there will be nothing but air bubbles being picked up, also it will cause it to vent. If you are a tad above the full mark when it's hot prolly won't do much, but I wouldn't want to be too much overfull. It's very common for a tranny to suck up fluid as it runs through the gears and fills up the converter all the way. When I start with a dry trans I usually fill it up, till it's on the dipstick, then engage it into forward and reverse, and then I check the fluid again, because it will suck more fluid up, then I test drive it and check it again. As far as noise from being overfull of fluid, I can't really say it would make noise, since I really haven't payed much attention. I suppose if it was really arrating the fluid you could hear the pump whining, but that is just speculation. I'm assuming you didn't change the ring gear with the differential, so maybe you are hearing the whine from it not being a matched set. I've used unmatched sets before with no problems, but you never know. Is this whine still a constant whine, that doesn't seem to matter if you are moving or not?
  19. #19 Re: Tranny whine after diff and diff case replace...
    Barksdale AFB, LA
    From the first post...
    Quote Originally Posted by Tengis View Post
  20. #20 Re: Tranny whine after diff and diff case replace...
    Fort Wayne, IN
    Just as Vermsta said you should check it multiple times as the fluid level will drop after things are apart and definately check it again after a road test to verify it is full. If it is low again then I would suspect it leaking somewhere OR check your coolant overflow tank. This sounds odd but a customer of mine ran into this last year. His radiator was bad and trans fluid pumped into the radiator to the point where it was blowing out the top of the coolant over tank and leaking over the passanger side axle! Just keep an eye on the fluid level, not sure what to say about the other noise you hear. Does it make the noise at all sitting still in P, N or D? or just driving down the road and coasting?
  1. CV Shaft Rebuild/Replace [*]
    By Reptile in forum How To Write-Ups/Tech Tips
    Last Post: 11-06-2009, 02:04 PM
  2. help removing altenator case
    By chitownchevy in forum Off Topic Discussion
    Last Post: 09-16-2008, 06:47 AM
  3. In case you guys didn't see the extent of my hacking:
    By Ron Vogel in forum Off Topic Discussion
    Last Post: 02-24-2008, 06:49 PM
