Man I'm getting tired of this. Just when I get to finally start enjoying my car after all the hard work I put in, something like this pops up.
Let me give you some history. Got the car in May, dropped the trans and changed ALL the trans solenoids to the components that Dave @ Triple Edge sells (all high quality Borg Warner stuff), filled it with Dex 6, and everything was peachy other than needing the engine replaced, which I did in August. The car has had NO problems since then.
So here in MD we just got a lot of snow, and the weather is really cold. I've had no problems for the past few days, was able to drive around just fine; car never got stuck, never gunned the engine in the snow.
Anyway, was driving to work this morning, and I'm cruising at about 30-35MPH. The trans shifts from 2nd gear to 3rd gear, and it shifts HARD. Not hard as in banging, but the car lurches forward at the gear change. I thought I hit a bump, so I try it a few more times, and, yep, it shifts hard from 2nd gear to 3rd gear. 1st to 2nd is perfectly fine. After a little while, it sort of goes away. Also, it might be just me, but I think that 2nd gear is finishing at a too high RPM before it shifts into 3rd. I think. I might be wrong.
When I got to work I checked the trans fluid and the fluid level. It's still red, not burnt, no funny smell, and the level is perfect.
What could be causing this? Would it be the cold weather (I doubt it)? Or is this a far worse problem that I'm hoping is not?![]()
I really don't have any money or time for a new trans or to be messing around with this right now.
Would a shift kit be an easy fix me up?
